Wheel offset?
Old Jun 19, 2004 | 06:57 PM
twotonestepside's Avatar
twotonestepside
Wheel offset?
I'm thinking of putting a set of weld Rodlite wheels and new tires on my 1985 F150 2wd and was wondering if anybody knew a good offset so that your tires dont stick out past your fenders or know how to determine the offset?
Old Jun 19, 2004 | 10:13 PM
5_labsownus's Avatar
5_labsownus
To determine the "backset" you can do the following. If the rim are the same no problem and if you are going for a replacement rim with the same width. You can get the backset by removing a rim and placing it face (or outside) down and placing a straight edge across the back of the rim lip and then measure from the straight edge to the center of the rim and that is the back set.
