instrument panel lights not right
Old Jun 22, 2004 | 11:56 AM
butchhutch's Avatar
butchhutch
Question instrument panel lights not right
the lights were I can see the instrument panel at night dont work..
when I turn on the left blinker: it works in the right place <---
when I turn on the Right blinker: it come on in the break light Section
when I start the truck up the far left light And The Right Blinker Light
comes on, then back off after motor is running. I know the far left light
is right. but not the right Blinker Light on start up .. Help I need my
instrument panel lights. Musician that drives mostly at Night....
I have replaced the Blubs!!!
Old Jun 22, 2004 | 12:58 PM
butchhutch's Avatar
butchhutch
But The Fuse Keeps Blowing
Old Jun 22, 2004 | 01:13 PM
emboyd's Avatar
emboyd
FIRST: Don't keep putting in new ones. It's blowing for a reason. And certainly don't put in a bigger fuse.
You probably have a short in some wiring somewhere. Have you done any other electrical work on your vehicle lately?
Old Jun 22, 2004 | 01:26 PM
butchhutch's Avatar
butchhutch
Just replaced the bad Ins.panel bulbs and replaced the Hi/Low Beam Switch on floorboard. I just got the truck !!!
Old Jun 22, 2004 | 02:01 PM
nzabka's Avatar
nzabka
I know for a fact that the hi/low beam switches in old chevys used to cause similar problems, I'm guessing that there're not wired much different in the Ford's. Did you replace the hi/low switch before or after the problems with the fuses? Are you sure you've got the wiring connected to the switch without any strays sticking out?
Old Jun 22, 2004 | 02:10 PM
butchhutch's Avatar
butchhutch
the problem was there Befor I replaced the switch
Old Jun 22, 2004 | 03:58 PM
nzabka's Avatar
nzabka
Sounds like a pinched wire or insulation off scraped off a wire that is touching something, most likely under the dash that's grounded, which would explain your problem. I would get a flashlight or trouble light and try to look up undernieth your dash for something obvious and even pull out the instrument cluster. You can get that out in 10 minutes. The hardest part on that is the headlight switch ****. It has a catch on the backside of the **** that you have to depress with a screwdriver or something along those lines, or at least that is how I got mine off.
If you have an ohm meter, I'd pull the fuse and check ohm out from the equipment side of the fuse to ground and start unhooking things one at a time behind the dash until the ciruit opens up, that is if there is a short showing resistance.
Old Jun 22, 2004 | 05:16 PM
butchhutch's Avatar
butchhutch
I will try the meter test. what side is the the equipment side of the fuse ?
Right or Left ?
Old Jun 22, 2004 | 07:03 PM
nzabka's Avatar
nzabka
Off the top of my head, I don't know which side is the supply side and which is the equipment side. If your ohm meter can do volts or you have a test light, just pull out the fuse and see which side has 12 volts and which does not. You want the side that does not have 12 volts.
By the way, when exactly does the fuse blow? Does it happen immediately after you replace the fuse and before you turn on the lights, or does it happen after you turn on your lights? If it happens after you turn on your lights, my guess would be the actual headlight switch in the instrument panel or the wiring leading up to it.
Old Jun 22, 2004 | 07:11 PM
butchhutch's Avatar
butchhutch
It happens after, I turn on the lights...
Old Jun 22, 2004 | 07:34 PM
nzabka's Avatar
nzabka
Well, if your like me (always low on cash, that is), your best bet is to start with the things I recommended above. I've personally never had this problem, but that's how I'd start in on it. Someone may come along in the next day here and give you some more pointers.
Hope you find it!
Old Jun 22, 2004 | 07:39 PM
butchhutch's Avatar
butchhutch
I will Check the headlight switch in the instrument panel or the wiring leading up to it. and then post back on it Thanks
Old Jun 22, 2004 | 08:42 PM
butchhutch's Avatar
butchhutch
I has Corrosion here in the red connecting two poles togather. hoping that was it, so I cleaned it off. I will have to wate till Light to check all the wires..
Old Jun 23, 2004 | 07:53 AM
nzabka's Avatar
nzabka
I'm guessing that'd be a good candidate for the blame. Hope that's it.
Old Jun 23, 2004 | 09:40 PM
butchhutch's Avatar
butchhutch
Changed the Headlight switch. Fuse is not blowing now.
But still same problem. someone said sometingh about the
Turn Signal Switch. I guess thats the next thing on the list..
