Have a lighting problem
Old Jun 20, 2004 | 11:59 AM
Piscesms9's Avatar
Piscesms9
The tail lights and dash lights just up and quit working both at the same time. headlights, brake lights and blinkers work fine. I have checked the fuses and they all look fine. Where do I look next? This problem is on a 1984 F-250 diesel PU. Thanks
Old Jun 20, 2004 | 12:09 PM
Jimbare's Avatar
Jimbare
all alone in the world
next would be the headlite switch.
check the fuses again and make sure they are alright.
jim
Old Jun 20, 2004 | 12:41 PM
Piscesms9's Avatar
Piscesms9
How do you check the headlite switch?
Old Jun 20, 2004 | 12:47 PM
Piscesms9's Avatar
Piscesms9
How do you check the headlite switch? Thanks for advice I will recheck fuses also.
Old Jun 20, 2004 | 03:39 PM
hermangarza's Avatar
hermangarza
under dash to your left bottom has like a square harness
Old Jun 20, 2004 | 09:58 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Somethings wrong there cause his front park lights are still working, right??? If they are it must be wiring if not, I'd guess headlight switch too. Just pull the switch out of the dash and bypass the terminals before you go and buy a new one.
78fordguy
64
Jun 8, 2014 06:18 PM
ehockey2000
1978 - 1996 Big Bronco
Mar 30, 2011 08:54 PM
jjbigwheel
All Things Towing
Sep 28, 2006 08:16 PM
74f100gg
Apr 14, 2005 12:41 AM
viralstrain
Sep 18, 2003 09:20 AM
