pto pump
Old Jun 21, 2004 | 03:21 PM
DMAN's Avatar
DMAN
pto pump
I have an 85 f-350 4x4 diesel with a 4spd tranny I need to know if a pto pump and controls off of a 73-79 2wd 4spd will fit my tranny.Thank You
Old Jun 21, 2004 | 06:22 PM
Jimbare's Avatar
Jimbare
all alone in the world
if the trannies are the same,[i.e. borgwarner, or new process.] the p t o will fit.
what do you mean by controls? do you mean the p t o shifter? or do you mean a hydraulic pump? i need a little more info.
jim
Old Jun 21, 2004 | 08:58 PM
DMAN's Avatar
DMAN
I mean the whole setup so I can bolt it to my truck and run a dump bed with it. Where do I find a tag that tells what the tranny is?
Old Jun 21, 2004 | 10:15 PM
Jimbare's Avatar
Jimbare
should be a tag on the side of the tranny with everything on it. brand series and so forth. i dont think you will have enough room for the pump between the tcase and the mounting point. do you know which side of the tranny the p t o is mounted on now?
are you going to have a problem with the front drive shaft or the exhaust? so many variables to contend with.
jim
FireEngineMike
1947 and Older Ford Trucks
Mar 9, 2015 04:01 PM
1952henry
Ford Truck Parts for Sale
Feb 22, 2015 12:55 AM
hooson
WTB - Parts & other
Oct 18, 2014 06:21 PM
50f6
May 30, 2014 02:47 PM
