Fuse keeps Blowing
Old Jun 22, 2004 | 01:00 PM
butchhutch's Avatar
butchhutch
Question Fuse keeps Blowing
Fuse keeps Blowing on my instrument panel lights
Old Jun 22, 2004 | 01:11 PM
emboyd's Avatar
emboyd
FIRST: Don't keep putting in new ones. It's blowing for a reason. And certainly don't put in a bigger fuse.
You probably have a short in some wiring somewhere. Have you done any other electrical work on your vehicle lately?
Old Jun 22, 2004 | 03:13 PM
lmadore's Avatar
lmadore
Definitely don't put a bigger fuse in.
I would suggest removing the dash cluster and taking a look at the cluster and the harness.
Old Jun 24, 2004 | 12:21 PM
cobburn's Avatar
cobburn
did you put an aftermarket radio in it? if so pull it back out and make sure you tape up the light blue wire with the red stripe on it. That is the wire that illuminated the stock radio when the parking lights are turned on.
Old Jun 24, 2004 | 02:36 PM
butchhutch's Avatar
butchhutch
I just got the truck. it has one in it, But I unpluged the power wires to it...
Im now looking for a steering weel Puller, were I can replace the Blinker switch.. allready replaced the Hi/Low beam switch & Head Lights Switch.
and all cluster blubs. fuse is not blowing now..But the reason for the post is my Cluster Lights Not working...
Old Jun 24, 2004 | 03:09 PM
cobburn's Avatar
cobburn
yea i know you reason for post. that wire is part of your cluster light circuit. if you look at the wires that go to each cluster bulb, it is light blue with a red stripe, the same wire that goes to stock radios, so if that shorts out of course it will blow the fuse and your cluster lights will not work.
Old Jun 24, 2004 | 03:49 PM
butchhutch's Avatar
butchhutch
The cluster bulb's plugs into a thin plastic circuit Board. not a light blue with a red stripe wire.. maby I missing somethin here ?
I have a plug with about 15 to 20 wires in it.. that plugs into the cluster circuit Board...
Old Jun 24, 2004 | 09:33 PM
cobburn's Avatar
cobburn
yea well look at the wire to the light that illuminates the headlight and wiper switch.
Old Jun 25, 2004 | 05:51 AM
butchhutch's Avatar
butchhutch
OK that wire seems to be ok. I traced it back to a wiring harness. but theres no Blub in it, so I dont Know if its getting Power [Dont have a tester]. Do you know the Type or size Blub for It ? I will go get one today..
Old Jun 25, 2004 | 06:31 AM
butchhutch's Avatar
butchhutch
Got The Blub that goes there. All is working now
Thanks for the Help .......now for the gas gage
Old Jun 25, 2004 | 07:11 AM
cobburn's Avatar
cobburn
gas gauge malfunctions most of the time are from the float in the tank filling with gas and causing very inaccurate readings. This is the most common problem but if it isn't that it's probably the sender. but if it isn't that test the gauge. to test the gauge, ground the sender side of the gauge as it should then read "full", with the key on of course.
Old Jun 25, 2004 | 07:32 AM
butchhutch's Avatar
butchhutch
gas gage works half way.. I full the truck up & Gage reads Full = Right
at half way Mark Still good. but right before 1/4 mark goes to empty...
Old Jun 25, 2004 | 07:41 AM
butchhutch's Avatar
butchhutch
Got something else too Blinker Lights , Blink on wrong Place..
Can I just switch the Brake and Blinker Face Plates ?
are all the face Plates in the righr Order ?
Old Jun 25, 2004 | 08:40 AM
cobburn's Avatar
cobburn
sounds like a fuel sender problem. as for the blinkers blinking the wrong light, take it all apart and switch the bulbs around. those bulbs have pigtail sockets that lock in to that dash piece and then the bulbs push into them. to get the pigtails out just turn it to release it and then pull it out from the back and switch it.
Old Jun 25, 2004 | 10:53 AM
butchhutch's Avatar
butchhutch
I've Tryed doing that.. it does not help...
