Instrument Panel Gagues
Old Oct 14, 2007 | 02:04 PM
howlingwolf's Avatar
howlingwolf
Exclamation Instrument Panel Gagues
All My gagues quit working except my speedometer any suggestions?
THANKS
Old Oct 14, 2007 | 07:37 PM
Duncan10's Avatar
Duncan10
Only thing I could think of is the plug in the back of the instrument cluster or a ground wire somewhere. A little more info would be useeful like do turn signals work lights on dash etc.
Old Oct 14, 2007 | 09:35 PM
Piffery1's Avatar
Piffery1
The Instrument Voltage Regulator (IVR) mounted on the upper rear of the cluster supplies regulated voltage to the oil pressure, temperature and fuel gauges. If it fails, those three gauges do not operate properly. The ammeter is not affected but you can hardly see it move under normal conditions. Tachometer and speedometer are not connected to the IVR. Check to see if the instrument panel lights are working. If not, then suspect a bad ground connection at the printed wiring connector which will affect gauge operation, too.
Old Oct 15, 2007 | 04:14 PM
howlingwolf
Thank You I'll see if this does the trick!!!!!!!
MustangMatt96GT
29
Jan 5, 2009 10:21 PM
howlingwolf
Oct 14, 2007 09:51 PM
howlingwolf
New Member Introductions
Oct 14, 2007 01:22 PM
construction site
Electrical Systems/Wiring
Feb 1, 2004 11:16 AM
