T-case Shift bar, "clip" holder needed
Old Oct 14, 2007 | 07:55 PM
reamer's Avatar
reamer
Hi all
On my '86 F-150 4x4 with AOD and NP 208, I when to put-er in 4low when The lever "just slid back with no resistance". Oh crap! did I just lose the case????
Looked under neith, the shift bar fell off the T-case shift arm. This bar is held on with some sort of pressed on plastic clip.
Where can I get replacements? What is this "clip" called? Any part #?
Thanks
Reamer
Old Oct 14, 2007 | 08:10 PM
ri_truck_guy's Avatar
ri_truck_guy
Interesting....found the same problem with the same part today. Hopefully someone can answer this.
Old Oct 14, 2007 | 09:20 PM
reamer's Avatar
reamer
Scary feelin' aint it?
I saw dollar signs fly away.
I do need to re-build/swap out this 208. There has always been a "wind noise" since I got the truck 5 years ago.
I taped off everything on the front end trying to find it.
Found it, its the T-case.
Jacked up all 4 tires, Put it in D and.... there it is the "wind noise"
Put the T case it N and it goes away (with the AOD in D)
Must be a bering.
Old Oct 15, 2007 | 04:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by reamer
Hi all
Thanks
Reamer
E2AZ-7341-A .. Transfer Case Rod Bushing for A/T (manual trans uses different bushing)
Good News: Still supplied by Ford, list price $2.90
Old Oct 15, 2007 | 07:22 AM
reamer's Avatar
reamer
thanks Numberdummy!
Ron
reamer
Oct 7, 2016 10:50 PM
reamer
Feb 21, 2016 10:26 PM
reamer
Feb 2, 2016 10:31 PM
reamer
Jan 5, 2014 08:20 PM
BigJake86
Aug 6, 2002 05:18 AM
