Driver front blinker not working, everything else does
Old Oct 14, 2007 | 05:30 PM
wmsteward's Avatar
wmsteward
Hello, Have 1981 Ford F250 4x4. The front driver side blinker does not work. All other blinkers do. It does work when running the Emergency Flasher. The fuse is good, the passenger side blinker works. The emergency lights all work, the bulbs are all new, I did notice some where on the wires right up close on the bulb holder but I have pulled those apart so as to not allow any possible shorting but not sure if this is a problem or not. Please help. Thanks.
Old Oct 14, 2007 | 06:08 PM
IrishMike's Avatar
IrishMike
sounds like you may have a wire with bad conection or broke, check at the light,the fire wall and colum. Wiggle turn signal switch as well,I know this sounds crazy but my truck has done this once also. I had one round when none would come on, wiggled the key switch{truck was running} and they started working. Always check the ground, the ground is 98% of problems with eletrical. I hope this helps.
Old Oct 14, 2007 | 11:41 PM
Franklin2's Avatar
Franklin2
Is it totally dark, or does it come on solid, but not blink? Also, does the dash indicator work or does it act like the front light that doesn't work.
Old Oct 15, 2007 | 07:19 AM
srercrcr's Avatar
srercrcr
Since the flasher works at that location, I'd focus on the turn signal switch or the wiring connection to it.
Old Oct 15, 2007 | 11:43 PM
wmsteward's Avatar
wmsteward
reply
Thanks for the info. The light stays totally dark except when the emergency lights are working , the dash light and the front blinker works. And sometimes when I turn the drivers turn switch off, the drivers dash light comes on very briefly. I will follow the ground. Thanks to you all.
Old Oct 15, 2007 | 11:44 PM
wmsteward's Avatar
wmsteward
<TABLE><TBODY><TR><TD vAlign=top width="100%">Thanks for the info. The light stays totally dark except when the emergency lights are working , the dash light and the front blinker works. And sometimes when I turn the drivers turn switch off, the drivers dash light comes on very briefly. I will follow the ground. Thanks to you all.
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE><!-- / message --><!-- no sigs except when logged in --><!-- sig -->
__________________
tufftruck
Nov 10, 2016 12:54 PM
rossseger
Nov 3, 2014 02:09 PM
will32_
24
Sep 28, 2014 10:18 PM
balingwire
Dec 6, 2009 07:57 PM
