- '96 Explorer a/c compressor question.
- 04 Explorer Steering
- TSBs
- 97 Explorer Headlight Problem
- Oil change mess
- Brake pedal sticking 1997 explorer
- Transmission Fluid Change - When?
- ABS Light Still On 99 limited 5.0
- Clogged Windsheld sprayer
- 86 2.9 idles decent, but dies when trying to give it gass.
- URGENT! please help with 99 explorer trans problems
- Help with manual transmission trouble 99 explorer
- Flash Engine Light check
- Paint
- What is the right idle speed
- Ford explorer 1997 Hot soak starting problem
- Front Differential/Xfer case fluid change(?_
- Headlight/Foglight Problem
- '99 ford explorer-is it the tires?
- 2002 Ford Explorer V6 Towing Capacity
- Green Filters
- Autohub-Spindle nut socket
- Not sure what is wrong???
- New guy saying hi!!
- How TO Replace the Intake O rings?
- couple of questions, battery, starter
- Took Home 99 Explorer
- 1995 Ford Explorer Limited Sound Problem
- 93 Explorer Passenger Side Humming???
- 96 Explorer Keyless Entry
