Transmission Fluid Change - When?
Old Sep 21, 2004 | 08:24 AM
blend-door-lover's Avatar
blend-door-lover
I have a '97 V6 4.0 SOHC Explorer with 97000 miles. I assume the tranny fluid has never been changed. Truck runs fine. Should I change the fluid now? What is the change interval? Truck is not used for towing. How much for a shop to change?
Thanks, Phil
Old Sep 21, 2004 | 09:02 AM
devil421's Avatar
devil421
Its due for a change. The usual is around 60K miles. The price varies but Id expect to pay about $150.
Old Sep 21, 2004 | 09:19 AM
Justmill3's Avatar
Justmill3
I had a Chevy blazer with about 100K miles and look it for a Trans flush,,well after they flushed it, the trans went out. Literally would not make it out of the parking lot.
I have heard that if you are way over due for a flush, the old fluid acts like a glue (all the shavings) and when you flush it, you are SOL. (like I was)
My $59.99 flush turned into a $1,500 new tranny.
Old Sep 21, 2004 | 09:30 AM
devil421's Avatar
devil421
This has been debated back and forth many times. Ive heard from very reliable sources that this should not happen much at all. It is a consideration but the alternative is not very attractive either (dirty fluid forever WILL destroy your tranny too). Get it flushed and hope for the best.
Old Sep 21, 2004 | 09:45 AM
holiday187's Avatar
holiday187
get your self 10 quarts of royal purple atf my wife's truck run absolutely great with it.
