- possible ball joint
- Cracked liftgate panel, anyone?
- Argon smoke test for fuel leak
- OBDII plug not working?
- 1996 Explorer Transmission Problems
- 1994 explorer/ v-8
- OD Drum Sensor Delete?
- rear spark plug
- Transmission swap issue
- Rough when cold
- no heat or ac is going thru the vents?
- ever used a *tune*
- 94 Explorer 4.0l has acceleration problems.
- Check eng. light (EGR)
- 2000 V-8 Explorer Towing
- P0304
- Explorer 97 XLT Ball Joint- Help!
- O/D Light on & off, blinking ect.
- 06 Explorer Navigation System: breadcrumbs
- 2000 Mount wouldn't crank in the cold
- 2002 explorer window wont go up!!!
- '92 explorer battery ground
- '97 Explorer, odd idle sometimes
- Buying an '01 Explorer...things to look for?
- 96 xlt odometer inop
- 95 explorer Shuttering
- 2002 Explorer
- 94 Explorer 4wd 4.0 Pushrod Koeo 335
- Still having problems with 1996 Explorer starting
- '97 Explorer Will Not Start???
