- '98 Explorer repairs
- 1996 Ford Explorer 4.0L 4X4 High Idle
- New Owner - 2003 XLT
- heater Problems
- 4 X 4 clunks on right side when enganged
- Rear Window Defroster Repair
- Problems with Overdrive
- So the next question is.....
- '00 Explr 8.8: Which Size X-pin?
- Heater Hose valve assembly
- Is that my fan clutch whining? Do I replace?
- Remote Starter?
- New 02 explorer sls 4wd 4dr
- trans. problem
- Help with lower ball joints
- Narrowest tire for stock Exp. Sprt Trk Rims?
- third brake light relplacement?
- Has anyone had this happen?
- Radius Arm Bushings
- 4x4 and A/C Problems
- No 4x4 low
- Sagging Rear Springs
- Lucas Upper cylinder lubricant problems?
- trouqe converter lockup
- No Fog lights when the brights are on
- Flashing lights
- explorer question
- Explorer 5.0 question
- Rear end moaning at speeds under 10mph
- Hubs grinding / buzzing / noisy when disengaged
