- '92 explorer gearboxes. destroyed 3 of them in 4 years.
- Intermittent Shifting Problems AT
- Air Shocks vs. HD Spring assist in rear
- 92 XL-repalce front seats Q
- Which wire is accessory? & No Hi-Levels
- Help !97 Explorer won't start
- 1999 Ford Explorer
- 96 explorer c.e.l.
- 93 tranny prob.
- Better suspension for 2wd 92 XLT
- Flasher/ turn signal problem
- Gas mileage issue
- Gas pedal adjustment exp. 97, 4X4
- Advice on tires, brake light for 97 Explorer
- No Interior Light w/ Driver's Side Door Open
- Shackle Info Needed
- 00 transfer case chain jumping-anyone rebuilt one?
- 94 Explorer Check Engine Light and hesitiation at high altitudes?
- 97 Explorer Rear Shocks
- changing rpm problem
- explorer idle dropping to occasional stall point
- Can you recommend a code scanner?
- Negative Side Coil Wire for a 2004 Explorer Sport Trac?
- 95 Explorer running cold
- clutch problem please help
- ABS code 17
- What would it take....
- AC/Heat problems
- 00' X woofer replacement
- yet another question
