- SOHC Good years versus bad years?
- front grill for explorer
- Rear Noise "whoop whoop whoop"
- 03 Sport Trac Towing Simulation
- 2001 Sport Left Brake Light/Turn Signal
- '02 Explorer jumping into 4Lo...
- 02 exploder q's
- Hard start, rough idle, stalling
- want sport trac
- could it be...?
- PATS Key programming problem...
- fuel pump pressure
- 2007 Sport Trac Radiator
- Flex Fuel to Non Flex Fuel Engine Swap
- Explorer 4.0 sohc dripping fuel from t/b
- 2005 sport trac wheel bearing
- 2wd mountaineer front bearings
- Check suspension light???
- 4.0 SOHC Timing Chain(s) Broke
- 96 Explorer codes p0300 302 306
- Engine heater '02 Sport Trac
- Elecectrical Question? daytime running lights?
- 2003 Cruise control problem
- Anyone try the Accel DOHC COP's (140034-8)??
- Replacing headlight assemblies on a 98 Explorer
- AWD GONE?!?
- 4wd Non-Functional on First Generation Explorer
- 99 explorer gear indicator adjustment
- 05 v8 burning oil
- howls under left pressure
