93 Explorer Passenger Side Humming???
Old Sep 18, 2004 | 08:50 PM
CyberPhreez's Avatar
CyberPhreez
Unhappy 93 Explorer Passenger Side Humming???
Hello all, this is my first time posting here. I have searched and searched the internet & ABOUT.COM looking for a solution to my problem but nothing has helped yet. Now to the problem;
I have a 1993 Ford Explorer XLT 4WD and for the past few months there has been a humming comming from the front of the vehicle on the passenger side. I could swear the noise is from the tire. It sounds like a humming or even comparable to the sound of a plane flying over-head. At first I thought it was the road as it gives an impression of cracks in the road. It has slowly gotten louder and it happens when we are moving. At slower speeds it's not so loud but the faster we go, the louder it gets. It doesn't matter if we hit the gas or not, just how fast we are moving. My wife and I agree that the sound is ONLY from the passenger side in the front. We can also feel a vibration under the floor on the passenger side which again, gave us the impression of going over cracks in the road. Does anyone know what this could be? I really don't have ANY money to take it to get looked at because we are in the process of moving right now. Please help!!!
-Randall Mikulas
Old Sep 19, 2004 | 11:54 AM
CyberPhreez
Anyone?????
Old Sep 19, 2004 | 12:40 PM
1081's Avatar
1081
You may have a bad tire. Take a little time and rotate the tires and see if the noise moves to wherever you move the current front tire.
Old Sep 19, 2004 | 03:28 PM
nailhead_sled's Avatar
nailhead_sled
When was the last time you packed your wheel bearings? They often omit a humming noise when they fail.
Old Sep 19, 2004 | 03:41 PM
CyberPhreez
Not sure when the bearings were last done, I just bought the Explorer about 7 months ago. And I shouldsay that the sound is actually more like a ROARING than a HUMMING. Actually sounds like an AIRPLANE taking off. The sound is not quiet either, it's quite loud. Also, the more weight that is put on that side of the vehicle (more people) the louder it gets.
Old Sep 24, 2004 | 09:24 PM
johnsona0's Avatar
johnsona0
Automatic Hubs
Do you have automatic hubs? Because I had the same problem that I traced to my automatic hubs.
Old Sep 27, 2004 | 02:57 PM
CyberPhreez
I do have automatic hubs? What could the problem be with them???
Old Sep 27, 2004 | 03:05 PM
johnsona0's Avatar
johnsona0
The problem with my automatic hubs was that there was excessive wear and that had caused metal particles to shave off the gears. The particles were causing a clicking kind of hum in the ratchet in the hubs. The only way to fix that (for me) was to get new hubs.
Old Sep 28, 2004 | 09:22 PM
TomCarperNGiles's Avatar
TomCarperNGiles
Also, look and make sure that the hub has disengaged. Most recomend that the hubs should be cleaned and relubed at least twice a year. Raise the right tire off of the ground and spin it while looking to see if the shaft is turning also. Should not be if not in 4WD.
davidjurss
Jul 2, 2011 06:03 PM
1897ranger
13
Nov 19, 2008 02:23 PM
duck fan
16
Apr 9, 2008 06:23 PM
cdrmotorsports
General Automotive Discussion
Mar 14, 2007 01:43 PM
overtow
Feb 5, 2004 04:30 PM
