- Transfer case swap, front drive shaft
- Sensor location?
- Heater Blend Door Actuator Plastic Gear Stripped
- code scanner
- erg sensor on a 1999 ford explore xls
- Front Brakes on an 07 Explorer
- 2002 Ford Explorer Blend Door Fix
- 2003 Explorer electrical failure HELP
- 2005 F.E. Xlt - Tranny shifting
- strange valve thing on fire wall next to master cylinder
- transfer case or not??? 97 explorer
- 03 front pinion seal
- 2002 Explorer Airbag 3 flashes then 4
- Can't adjust the heat!
- BANG in 97 Exploder 5R55E Trans !
- 2001 Sportrac leaky rear axle seal
- 2008 Mountaineer AWD
- ABS light-no code
- boat trailer lights no brake lights
- Explorer instrument backlights are out
- I'm an Explorer Newbie just got a 94
- 94 explorer needs new home....
- ford explorer/2000/4.0Lsohc v-6
- questions about tire sizes
- Explorer oil pressure sensor location??
- Plan to do some fluid changes soon
- 93 Explorer Master Cylinder
- 1994 transmission fluid change
- Clicking time bomb
- 06 gear selector lights not working
