- Has anyone had these issues?
- 4x4 Not Working on Explorer 94
- 91 Explorer will not start
- tranny 99 Explorer?
- Check engine light following interior water intake
- Pushrod vs SOHC - Pros and Cons?
- slight skip
- Cassette won't play out one side
- Engine stops, like someone removed the idle
- 95 explorer vacation troubles
- High performance chips?
- Speedometer fluctuation w/ OD Off light intermittant flashing
- Squeaky Suspension
- what motor can I use?
- 96 Explorer harness doesn't light up trailer
- 91 explorer won't start after accident
- 97 4x4/4x4low lights flashing
- trailer wiring ?
- lifts
- 1996 4.0L motor
- 1994 Ford Explorer Remote Keypad Programming
- 1994 Ford Explorer - Check Engine Line (code 226)
- what years did the 5.0L have mass-air?
- injector flow rate on '92 4.0 Explorer
- 92 Explorer Overheating - TRIED EVERYTHING! HELP!
- What's this 98 Sport worth?
- headlamps stay on with the switch turned off
- 1998 Explorer Power Antenna Replacement
- Explorer Fuel Gauge screwed up
