- 4.0 SOHC MAF,TB, Injector Sizes ??
- 2000 explorer stalling/sputtering
- Intake leak 96 push-rod 4.0 v6
- After my tune-up
- 97 Explorer V6 A/T - Problem shifting into gears on column
- Belltech 3815 Lowering Springs
- bad computer ground
- Can't remove rear wheels
- Slip Yoke/Rear driveshaft
- jfranks blend door fix----Question
- 92 Engine noise...tic
- Help!! 1997 Ford Explorer-tranny
- 95 X - tran fluid, cd changer, climate ctrl
- 97 Explorer 4WD not working
- Whats in the 00M12 kit
- #3 cylinder miss fire code
- Will Not idle and dies unless you race the engine
- 04 exp ticking in dash
- 2002 Explorer fusebox diagram?
- belt noise in 98 explorer xlt 4.0L SOHC
- How do I remove the rear interior liftgate panel on 97 explorer!?
- belt noise or pulley noise?
- Paint Color
- 2001 Explorer Front end shimmy
- Check Engine Light Code Retreival
- '98 5.0 V8 - A/C Low pressure port
- O2 Sensor code P0133 on '96 Explorer - I've got questions
- Looking to buy Explorer
- I'm Back, Again..
- 92 Ex fuel pump
