- Morning stalls for an '03 explorer
- 91 explorer, How to reset check engine light?
- '06 Explorer way to slow 4.6L!!! HELP!!!
- cold start
- problems with steering on Explorer plus front end noise
- Oil Pump Replacement 92
- Pinging under WOT
- differential fluid level on 02' explorer
- 2001 explorer sport track
- 03 Explorer, Hatch is cracking under glass....
- Is the passenger side rear seat supposed to fold and lock on a '03 Sport Trac?
- Drivers Side Door Will Not Unlock
- Cooling fan
- 06 explorer won't shift
- 4wd wont engage
- Super White Bulb 9007?
- 99 Explorer Warm Start Stalling - Cured
- 92 ford explorer, Idles wrong
- Replace '96 "premium" radio/cassette...
- remote starter
- rear differential fluid change
- 1999 Ford timing chain problem may be?
- Ford Explorer 1999
- Rear A/C problems
- Can you add fluid to auto trans??
- 1996 Eddie Bauer Explorer
- 2003 Rear Axle Leak AGAIN!
- New brakes for my 2003 Explorer
- Lift gate lock
- blend door observation - read if you haven't had this problem yet
