- Headlights stay on! Help
- 91 explorer, wont shift to third
- 03 Transmission - rebuild or replace?
- 1994 "codes"
- Bizarre smell and hot rear rim
- Radio size for 99 Explorer
- 2001 Explorer Sport Trac Tailgate needed
- 4.0 SOHC Balance shaft bearings!
- P0303 code showing up 97 Explorer 5.0
- head light moisture
- Can you remove the front axle and still drive the truck
- Where to get carbon fiber dash trim kit for 97 Mountaineer?
- Did Ford improve the trans/axles from 2002-2005?
- HID Help - 03 Sport Trac
- Looking to buy an '04 Aviator
- Battery killer...
- Bolt sequence and torqe on 96 4.0
- Sport Trac, 150,000 miles and need service
- Awd
- New User
- 2000 Explorer Sport Thump on Deceleration
- Replacing Brake Master Cylinder 99 Explorer
- 98 transfer case
- random not start
- 03 exp 4x4 front end vibration
- 4.0 SOHC hesitates and hiccups on take off
- Heater blend door problem
- Sohc ?
- what year explorer disk brakes
- 06 Transmission surge/hesitation problem
