- Top end tapping and slapping
- 96 fm antenna
- Cruise wiring help
- 02 explorer dash squeak
- Is it worth it!!
- Bouncy Speedo on my 1994 Ford Explorer 2WD
- 4.0 OHV upgrades?
- Timing chain - noise before failure?
- 97 Explorer Limited Climate control, high only!!! HELP PLZ
- Lighting on instrument panel out
- Preventing blend door problems??
- General Towing Questions - Mountaineer
- Squeaky lower ball joint...
- Service Question
- Removal of Front Rotors 1998 Explorer
- Replacing Spark plugs
- Left Turn, then bearing noise?
- A REAL Explorer Sport
- My 2000 Explorer Sport is hard to start after siting for a couple of minutes.
- Trans Rebuild Kits & Torque Converter Question
- 1997 ford explorer 4wd od light "on"
- whats this fuse for?
- auto door lock module
- 1992 Ford explorer vibration
- 2000 4.0 OHV Air Temperature Sensor
- What is included in Tow Package
- Where is the PCV valve located??
- MAF sensor cleaning, Ping, '94 Exploder
- What brand are factory plugs?
- cooling system
