Clogged Windsheld sprayer
Old Sep 20, 2004 | 09:57 PM
glipscomb's Avatar
glipscomb
I believe my front windsheild sprayer is clogged on my 2002 Mountaineer. I filled the resaviour with water but it takes a long time to spray out on windsheild and when it does it tickles out. Does anyone know what I can do to unclog it? Would it be better to replace each nossel? Any info would be appriciated.
Old Sep 21, 2004 | 07:55 AM
JerrySimm's Avatar
JerrySimm
One trick I've used in the past is to use 12 volt compressor and the small tapered nozzle that usually comes with them. Take the hose loose at a connection and blow through the spray nozzles, preferably with some liquid in the hoses. The hydraulic/pneumatic hammer helps to dislodge any foriegn matter in the sprayer nozzles.
