- 98 Ford Explorer XLT Sparks
- Electronic Compass/Temperature display
- 04 Explorer diag problem
- Rust...?
- 96 explorer repair costs
- Power Steering Leak 91 Explorer 4x4
- 01 sport trac throwing code, need help
- 2002 Exp Power window not working
- Melted Coil Plug Harness?
- Shaking front end/steering wheel
- Shifting Problem
- Brake light
- Tire Pressure Monitoring System
- 02 Eddie Bauer Explorer Radio Trouble
- adjusting transmission bands
- 1997 Explorer idle problems
- unusual vibration while turning
- key switch
- brake help
- Intermittent vibration
- 2001 Explorer Sport - EGR
- 95 Explorer Fuel Pump Issue
- 94 explorer aftermarket cd wiring harness
- Clutch Replaced.... Now What?
- '00 4.0L SOHC Fuse #13 keeps blowing
- power window problems
- Blend door fix - Thanks jfrank
- Valve replacement cost?
- Power Door Lock ????
- Self Test
