OBDII plug not working?
Old Nov 1, 2006 | 05:31 PM
tinol99's Avatar
tinol99
Anyone ever hear of this not working. In MA we have emissions testing where they plug into this port. The inspection guy said he couldn't run the test because it wasn't reading anything. Anyone have this experience? Thanks.
By the way its a 2000 Explorer XLS.
Old Nov 1, 2006 | 05:52 PM
Coastiejoe's Avatar
Coastiejoe
There is a ground wire that is one side of the loop. By that, if the ground is poor, broken or corroded, you will not have a reading when you plug into the data port.
IF memory serves me correct, you should see a single black wire coming into the port from the back side. Either test that wire for continuity to ground or trace it back to see if it is a ground. If need be, clean or re-new the connection.
Old Nov 1, 2006 | 06:16 PM
tinol99's Avatar
tinol99
Thanks, I see the black wire but it goes into the main harness. I have access to a digital voltmeter but how would I test it? Thanks for the help.
Old Nov 1, 2006 | 06:21 PM
Coastiejoe's Avatar
Coastiejoe
Go from the black wire to a good ground. If there is little to no resistance, you have a good connection.
Lots of resistance, or an open reading, you have an issue.
Old Nov 1, 2006 | 06:30 PM
tinol99's Avatar
tinol99
Thanks for the help. i will give it a try.
Old Nov 1, 2006 | 07:33 PM
projectSHO89's Avatar
projectSHO89
Far more likely it's just a blown fuse instead of a ground wire problem. Pin 16 of the OBDII test plug has to supply vehicle power to the scan connection.
On many of the F-series, it's on the same circuit as the cigar lighter. I'll check the EVTM tomorrow and see what they did on the Exploder.
Consult your owner's manual for the fuse listing.
Steve
Old Nov 6, 2006 | 12:27 PM
phatpony's Avatar
phatpony
Definately check the fuse. Mine did the same thing. I removed the fuse, checked it over, reinserted it because there was nothing wrong with it, and it has worked great ever since.
Old Nov 6, 2006 | 12:51 PM
tinol99's Avatar
tinol99
It was the fuse. Replaced it and everthing works again, including the fog lights and the rear wiper! Wierd. Thanks for the help.
