Coolant leak help
Old May 25, 2022 | 09:16 PM
  #451
Yahiko's Avatar
Yahiko
FTE Remembers
That is part of the oil intake port it looks like.
Old May 25, 2022 | 09:26 PM
  #452
TooManyToys.'s Avatar
TooManyToys.
I remember it Sean.
Old May 25, 2022 | 10:47 PM
  #453
Yahiko's Avatar
Yahiko
FTE Remembers
With all the stuff I packrat you think I could find it on my computer.
Old May 26, 2022 | 01:33 AM
  #454
Hartwig's Avatar
Hartwig
@ blicharski1989: I wonder how the gear could come loose on your pump. Is it possible that you used a tool on the central gear screw of the pump to turn/crank the motor by hand? If so, it may have come loose?
With the early pump, a half turn of the central screw counterclockwise is sufficient for the gear to become loose and no longer drive the pump!
Old May 26, 2022 | 04:33 AM
  #455
blicharski1989's Avatar
blicharski1989
Yeah it’s possible that I may have accidentally caused it to be loose. There’s not much holding the gear to the pump in terms of friction. Purely that bolt. I’ll be curious to see how the new pump performs. I wonder if my WOT values will be increased due to a stronger pump.
Old May 26, 2022 | 06:45 AM
  #456
Hartwig's Avatar
Hartwig
What is incomprehensible to me about this is that the cam gear turns counterclockwise and drives the HPOP gear. That means that the central bolt of the HPOP is tightened during operation because the wheel of the HPOP rotates clockwise and it is theoretically impossible for this to loosen
Old May 26, 2022 | 07:14 AM
  #457
TooManyToys.
Assuming the bolt head stays in relation to the gear. A lot depends on the friction under the bolt head for it to self tighten. With a non-keyed straight shaft, the resistance to slipping is all about the correct clamp force/friction between the gear and the shaft face in the back. The surface area under the bolt and its radius is the minor player.
Old May 26, 2022 | 09:06 AM
  #458
blicharski1989
I agree all that is holding that gear on is the friction from the fastener clamping the gear to the shaft face. The shaft is not even tapered it seems. Obviously mine was not sufficient but it worked for over 100 miles until it slipped. Once it slipped it was done for.
Old May 26, 2022 | 11:07 AM
  #459
HydroTek's Avatar
HydroTek
I suspect that part of the gear to shaft, friction design is to protect the cam gear in case the pump has a failure and locks the shaft -- kinda goes along with the press fit swash plate idea
Old May 26, 2022 | 01:40 PM
  #460
bismic's Avatar
bismic
Credit to @Ford_Doctor for these pics
https://www.forddoctorsdts.com/galle...50-60l-hpop-1/
https://www.forddoctorsdts.com/galle...51-60l-hpop-2/
https://www.forddoctorsdts.com/galle...-hpop-failure/
Plus the links to some early work on diagnosing an early HPOP that Sean eluded to is attached
Old May 26, 2022 | 02:01 PM
  #461
blicharski1989
makes sense
Old May 26, 2022 | 02:58 PM
  #462
Yahiko's Avatar
Yahiko
FTE Remembers
Thanks Mark that was just the one I was thinking about.
Originally Posted by blicharski1989
makes sense
I agree with thais idea and was wondering. Was there any thread and bearing mount on the shaft and bolt?
Old May 26, 2022 | 10:55 PM
  #463
blicharski1989
Hpop
Transmission mount torn
Mount
Mount
HPOP gear
Old May 27, 2022 | 08:18 AM
  #464
eldridge201's Avatar
eldridge201
Man, I just caught up on this after a few weeks or almost a month and was bummed when I got to the second test drive part. I'm really hopeful you get it figured out and it's something simple (I guess if you want to call a few hours of work "simple") and it's just the HPOP.
Old May 27, 2022 | 10:31 AM
  #465
blicharski1989
yep just waiting on my new HPOP to come today. Leak tested unit no issues. The HPOP gear came loose on the pump. It may have been my fault. I don’t really remember. Should be a non issue for a while. Engine ran fantastic before the failure
