Coolant leak help
Old Apr 24, 2023 | 03:56 AM
  #706
Hartwig's Avatar
Hartwig
Did you renew the IPR valve and the ICP sensor?
Old Apr 27, 2023 | 08:58 PM
  #707
blicharski1989's Avatar
blicharski1989
they were replaced about a year from My overhaul.
I used IDS to command IPR to a specific position to maintain steady pressure when idling at full temp after driving. I see the ICP act steady +- 5psi then occasionally it will jump around +- 40 psi and the engine will stumble a bit then smooth out.
either the IPR is sticking when hot or the ICP sensor when hot is behaving erratically. It did this before the overhaul too when heat soaked. Usually it runs 640 psi and 23.1% IPR stock tune at hot idle. Never has had an issue hot starting.
i gusss I can unplug the ICP drive around and if I can’t re-create the issue it’s probably the sensor getting hot and reporting bad data which the FICM tries to compensate by adding or subtracting pulse width to maintain a target fuel volume.
Old Apr 27, 2023 | 11:52 PM
  #708
Hartwig's Avatar
Hartwig
What do you get as ICP pressure when you disconnect the ICP sensor?
Old Apr 28, 2023 | 11:09 PM
  #709
blicharski1989
The inferred value I think 870
Old Apr 4, 2025 | 12:44 AM
  #710
blicharski1989
Update truck has about 30K on rebuild still going strong. Occasionally does the weird ICP jumps when heat soaked. No leaks. Mechanical fan clutch is annoying in winter but nice in summer
Old Apr 4, 2025 | 08:10 AM
  #711
Byrd.Dog's Avatar
Byrd.Dog
Agree. If it wasn't so expensive, I would try the electronic clutch again, especially since I don't pull a 5th wheel anymore.
Old May 13, 2025 | 06:11 PM
  #712
JakeS96's Avatar
JakeS96
4th Gear
My 2003 ZF6 truck has been doing this for awhile and I have been unable to figure it out too. I wanted to think IPR but when it runs inferred it is quite a bit better. Makes me wonder if it just resting in a different location at idle helps once it's hot. I still feel like it very faintly does it when running inferred driving down the road. Mine usually does it after longish drive, shut off and heat soak. Get back in with 150 to 160 degree temps and it will hiccup. Notice it pretty bad on a zf6 in a parking lot.
Old May 13, 2025 | 06:40 PM
  #713
blicharski1989
yeah what I have observed is that it commands 640 psi at idle, it will be around 22-23% IPR to achieve that pressure. When it’s acts up after heat soak it will sit around 26-27% IPR but the ICP will jump around like: 640-670-630-690-640 causing the engine rpm to jump around a bit. When it’s not heat soaked it will be like 637-639-640-642-639. Much tighter regulation. I can’t tell if the ICP is jumping around due to the IPR moving or if the ICP sensor acts incorrectly when it’s hot. Chicken vs Egg. I would need to replicate problem, use IDS to command a fixed duty cycle and observe the ICP pressure/voltage
Old May 13, 2025 | 08:16 PM
  #714
JakeS96's Avatar
JakeS96
4th Gear
If it's means anything mine has a new Motorcraft ICP and pigtail and it made no change. Harness has been ohmed out and checked. Was beginning to wonder if it's some weird HPOP issue or something else in the oil system. I have seen several 03 04 owners experiencing the same thing and have never gotten an answer. Mine will usually not throw a code but it has thrown a 2287 once.
Old May 13, 2025 | 08:57 PM
  #715
blicharski1989
I have a brand new engine harness, ICP, and IPR. I think it might be the programming. Sometimes it seems to get stuck in an oscillating loop. Maybe it’s the PID loop that drives the IPR position to
match the desired ICP. Too much or too little gain? All I can say is it only happens after the engine gets heat soaked like on a long highway drive or idling with AC on during summer for extended periods of time. Usually it’s high speed RPM operations for long times like 2200-2300+ rpm for 30 min or more. I thought maybe it was aeration with the oil
Old May 13, 2025 | 09:14 PM
  #716
JakeS96's Avatar
JakeS96
4th Gear
You're nailing it. I haven't been able to figure it out but it sure does drive me crazy. Feel like it's a good bit worse since I have a zf6. You feel it a lot more. I also get rev hang whenever it's doing it. You can also rev the truck to 2k in neutral and it will almost takeoff on its own. I can't really figure out what the next step to take is.
Old May 13, 2025 | 09:22 PM
  #717
TooManyToys.'s Avatar
TooManyToys.
When my truck had this problem when it was new, and it did so often, I ran the "self test" (I had IDS at the time, but other tools may be able to do this). It never did it again in 22 years.
Old Jul 15, 2025 | 04:54 PM
  #718
JakeS96's Avatar
JakeS96
4th Gear
I think I finally figured it out. I got eric at ID speed to get me a non inferred ebp 75hp tow tune. Has not missed a beat yet. ICP has been rock solid for 1000 miles now. If you need more info PM me. But this fixed mine.
Jamesglenn024
May 1, 2021 01:42 PM
Amicus
Oct 28, 2017 10:13 AM
Watcher58
Aug 10, 2016 11:20 PM
RavageX
36
Jun 5, 2013 06:30 PM
flitchplate
Nov 27, 2010 06:54 PM
