Coolant leak help
I did me the bubble test no problems there, what are the chances of two bad motor craft injectors?? Slim to none I feel like out of the box.
im wondering if I don’t have a stupid oil rail check valve issue. My symptoms match others. It’s really got me thinking ……
Cleared all my codes, went on a 5 mile test drive, did some pulls, monitored data, nothing wacky. Engine is idling smooth as can be. No code this time. I suspect this P0272 maybe coming back hard to say. No white smoke at idle.
Ficm?
Injector?
oil rail check valve?
mechanical engine issue?
I didn’t see this issue on the tow tune. It commands about ~1000 psi at idle. Maybe the injector on #4 is not happy at 640 psi? Makes me wonder…. #6 did not come back. Maybe it was a fluke or a miscalculation by the PCM.
You should check the cylinder balance with IDS, here you can see pretty much the problem.
In this video you see a dead No.5, No.2 and No.7 are also not optimal, but do not throw codes yet.
Do you have the possibility to exchange your FICM for a knowing good one? Otherwise, the only option would be to swap the injectors with each other to see if the error migrates. And let the EGR valve plugged in.
https://youtu.be/8o4F97OjRv4
I have a suspicion it’s these oil check valves on the 03/04 log rails. Gosh I wish I would have checked them out more during the nipple cup seal replacement.
this is what I’m thinking, it’s an 03/04 issue. There is a check valve of sorts on the oil rail quick connect fitting. It somehow becomes restrictive and chokes off the oil pressure at idle to the injectors. Causes almost phantom contribution codes. I did a bunch of research and my symptoms are very similar. It’s not a full misfire but it’s like a partial. Injectors 4 and 6 are next to each other. I’m willing to take the gamble and try to replace the one on drivers side. There is a TSB about this weird issue.
TSB 082001
https://www.ford-trucks.com/forums/1...ck-valves.html
TSB 082001
I copied the text below from the referenced TSB 08-20-01 (sorry for the text size on the headings):
ERRATIC HIGH PRESSURE OIL SUPPLY
Erratic supply of high pressure oil to injectors may cause a rough running engine. High pressure oil flow can be disrupted by faulty check valve(s) or a faulty injection pressure regulator (IPR) valve.To diagnose, first perform a slow neutral run up in park / neutral. If the engine runs rough between 1200 and 2300 RPM proceed to Check Valve Diagnosis; if the engine runs rough between 3000 and 4000 RPM, perform PC/ED pinpoint test Q, if the engine continues to run rough between 3000 and 4000 RPM after having validated the ICP sensor and connector, then replace the IPR valve.
- To isolate the bank with the faulty check valve, disconnect all of the injector electrical connectors on one bank.
- Perform a Power Balance test. Engine misfires should be constant on the four disconnected cylinders and the operational cylinders should be contributing evenly.
- Repeat Steps 1 and 2 on the opposite bank.
- If the operating contribution is erratic on one bank, replace the check valve on that bank.
Did you ever get your fuel pressure issue resolved for sure that you were having previously?
This post:
https://www.ford-trucks.com/forums/1...osis-help.html
Is it possible this has anything to do with what's going on now or what contributed to what led up to this whole $9k engine rebuild situation? Perhaps it isn't but I would hate to think that it could have something to do with any or most of this.
This post:
have you ever seen this oil rail check valve issue before on an 2003?
I can see if I can get an injector warrantied. Try that and the new check valve. That’s about all I got. Connections are solid. Fuel pressure is good. ICP/IPR are good.
Going to switch my tune back to the tow tune and see if the code goes away. It set the code again this morning within a few minutes of idling.
going to change oil to motorcraft today.
I called ford $165 diagnostic fee. I may take them up on that. It would be good to measure base engine compression, power balance, and whatever else they want to do.
at this point, it’s either bad out of the box injector, injector got some crud in it, or that stupid check valve, or an unlikely base engine problem
total miles on truck ~400
changes: 13 quarts motorcraft 15w-40 and 2 quarts of hotshots stiction eliminator, and a motorcraft oil filter. Changed back from stock to the street tune from blessed performance. Whats crazy is this more aggressive tune is actually running lower EGT than my tow tune which is supposed to be fairly mild. Maybe it’s a difference in injection timing? Maybe cylinder 4 and 6 spool valves were hanging up causing delayed injection?
it’s idling smooth as silk. 640 rpm +- 5 rpm. Call me crazy but the exhaust smells less “diesely”. There was never white smoke when warmed up but it seemed to have a less strong exhaust smell before I rebuilt it. Oil change and 15 mile drive and I can tell a difference. The engine is idling significantly quieter also. Goes without saying these HEUI oil systems are very sensitive to fluids. Maybe I had some gunk in the oil rails? Maybe there was some gunk in the engine?
I talked with the guy that sold me the injectors he will warranty them through Ford for me. I just want to be sure we’re not doing the parts throwing dance. I did order one of those check valves for the oil rail. I’d like to swap that out because it just involves removing the valve cover.
to be determined, sea trails take 3……….
