Coolant leak help
Old May 13, 2022 | 02:04 AM
  #346
Hartwig's Avatar
Hartwig
With how many steps did you torque the heads? ARP says 210 ft lbs / 285Nm, but it is tightened in several steps.
Old May 13, 2022 | 02:05 AM
  #347
blicharski1989's Avatar
blicharski1989
4 steps and lots of lube!
Old May 13, 2022 | 05:12 AM
  #348
TooManyToys.'s Avatar
TooManyToys.
Watch that relocation kit for leaking.
I would not put the engine back in with the FICM on. It's too much of a distraction.
Old May 13, 2022 | 06:47 AM
  #349
Hartwig's Avatar
Hartwig
Another question: the block was honed by a machine shop, right? How did you clean the oil galleries? Did you have the plugs in the block out for this?
Old May 13, 2022 | 06:50 AM
  #350
blicharski1989
yeah they hot tanked it, did machine work, then they jet washed it to make it sanitary and installed new plugs
Old May 13, 2022 | 06:51 AM
  #351
blicharski1989
good point! I’m skeptical at this point of the relocation kit
Old May 13, 2022 | 06:54 AM
  #352
Hartwig's Avatar
Hartwig
After 3 months, the parts for the rebuilt have finally arrived. I have unfortunately forgotten to order the plugs. Do you have any part numbers?
Old May 13, 2022 | 07:00 AM
  #353
blicharski1989
I didn’t order them but I think the oil ones are 3/8 and water 1 1/2”. you can also tap oil galleys for pipe plugs NPT
EXPANSION PLUG KIT FOR FORD 6.0L & 6.4L OHV ENGINES – PART # MPE-936R & MPE-936BR
Old May 13, 2022 | 07:07 AM
  #354
Hartwig's Avatar
Hartwig
The block I flushed several times on the coolant side, the plugs on the coolant side looked good, so I will not replace them.
But the plugs for the oil circuit I need.
Old May 13, 2022 | 07:09 AM
  #355
TooManyToys.
Old May 13, 2022 | 07:16 AM
  #356
Hartwig's Avatar
Hartwig
Thanks Jack.
Old May 13, 2022 | 07:23 AM
  #357
TooManyToys.
I've talked about 6.0 ICP relocation kits for some time, so I've also watched their application. Some people have had the fitting fail at the adapter to the HPOP cover, while others seem to have failed at the conversion of the ICP sensor seal, as the kits typically change from the captured o-ring seal to a dry fit seal. I also remember one hose crimp failure. I think JoeBlow had tried a kit.
I fitted up one with steel tubing and used a different adapter. It's not installed as I wanted to install it with the engine in the frame. Plus, I need to buy the tool to cut the original style port for the o-ring. I haven't moved on as you need good drilling equipment, and my woodworking drill press has too much runout for me to be comfortable making the precision port.
Old May 13, 2022 | 07:32 AM
  #358
Hartwig's Avatar
Hartwig
Unfortunately you live too far away Jack. Otherwise I would make you the machine work at the ICP sensor port.
Old May 13, 2022 | 08:21 AM
  #359
TooManyToys.
I know Hartwig, I know. My old director has a Bridgeport, but I haven't talked to him in years and he's 1.5 hours away. At some point I'll get off my tail and find a local. Or maybe buy the drill press I've always wanted.
Old May 13, 2022 | 05:44 PM
  #360
blicharski1989
I think I’m going to just run it in the stock location. My new up pipes are wrapped so I hope that plus heat shield around the ICP will keep it happy. I replaced it not too long ago. The worry of leaks is really making me hesitant
