Coolant leak help
Old Jun 27, 2022 | 12:03 AM
  #601
blicharski1989's Avatar
blicharski1989
Anybody got a loaner ficm to try before I spend another $400? Lol
Old Jun 27, 2022 | 08:26 AM
  #602
Brotherbillstruck's Avatar
Brotherbillstruck
Maybe heat soak your FICM (hairdryer) first before a cold start and see if it matches the poor performance hot? Compare with cold startup?
Old Jun 27, 2022 | 09:44 AM
  #603
blicharski1989
Yeah that was mentioned going to do it this week. Its a good idea.
Old Jun 27, 2022 | 09:58 AM
  #604
blicharski1989
Old Jun 30, 2022 | 06:47 PM
  #605
blicharski1989
Got my test FICM. Let’s see what it goes. Got my replacement injectors coming tomorrow. This weekend I’ll have the FICM, 2 injectors for cylinders 4 and 6 and then the high pressure oil rail check valve. It should solve it. Let’s cross our fingers
Old Jun 30, 2022 | 07:29 PM
  #606
Yahiko's Avatar
Yahiko
FTE Remembers
The one bad thing about doing more than one thing to repair/diagnose
an issue is thing 1 might fix it and thing 2 may undo the repair.
So I know it's more work. But the way to do it really would be only do one thing then retest.
Old Jun 30, 2022 | 07:46 PM
  #607
blicharski1989
going to start with FICM then drive around then do the injectors and check valve for next repair. I may do the check valve first and leave the valve cover semi loose so I can do the injectors next.
Old Jul 1, 2022 | 12:01 AM
  #608
blicharski1989
Ok we’ll FICM was a bust. Not much change noted during my power balance test. removed injector 4 and 6. No leakage past the copper sealing washer detected. It seems the new check valve may have a slightly larger hole. It’s not scientific but I can tell a difference in the resistance it takes to blow through the orifice. New one is less effort.
Old check valve for oil rail
New check valve for oil rail
Old Jul 1, 2022 | 12:09 AM
  #609
blicharski1989
Old check valve with photo editing to show orifice better.
Old Jul 1, 2022 | 08:36 AM
  #610
blicharski1989
Replacing injector 4 and 6 this weekend. Going to remove 2 and 8 to check them out for any signs of combustion leakage and then reseal them.
Old Jul 2, 2022 | 12:04 AM
  #611
blicharski1989
First fire with new injector in cylinder 4 and 6. Cold engine 30 seconds run time
15 minute test drive up to 192 EOT and ECT. 72F ambient temp.
Old Jul 2, 2022 | 02:24 AM
  #612
Yahiko's Avatar
Yahiko
FTE Remembers
Looks much better.
You should do it without the tune. All diagnostics values are
based on an untuned engine. So having the tune on skews the numbers.
Old Jul 2, 2022 | 07:04 AM
  #613
blicharski1989
Looks much better.
it’s already on the the stock tune
Old Jul 2, 2022 | 08:00 AM
  #614
TooManyToys.'s Avatar
TooManyToys.
That's why I said move 4 and 6 injectors, and if the dips followed, replace. I've been down this path.
Old Jul 2, 2022 | 01:06 PM
  #615
blicharski1989
I agree I would have done things more methodically but at the end of the time my time is limited right now to put into this thing. It was more about solving the issue as fast as possible. I do feel better having a newer FICM as well. Got a spare unit for backup just in case.
bad injectors out of the box happen I guess. We shall see. No codes have come back and the contributions are very similar.
Overall I appreciate everyone here and their input to help me with this project AKA money pit lol.
Have a terrific 4th of July and remember to think of those who made this wonderful country possibly.
