Engine removal pics
Old Oct 17, 2012 | 09:36 PM
  #376
run6.0run's Avatar
run6.0run
Should the casting numbers on the replacement block and my old block match???
Old Oct 17, 2012 | 09:37 PM
  #377
m-chan68's Avatar
m-chan68
Originally Posted by run6.0run
Does the 18mm block suck????
It doesn't necessarily suck. It's just older than what came out of your truck.
Old Oct 17, 2012 | 09:42 PM
  #378
run6.0run's Avatar
run6.0run
This is looking in the odd side stand pipe bore. The hg is chrome, or at least not black.
Old Oct 17, 2012 | 09:43 PM
  #379
run6.0run's Avatar
run6.0run
Would everything I have on my old engine work on the replacement?
Old Oct 17, 2012 | 09:45 PM
  #380
m-chan68's Avatar
m-chan68
That doesn't tell you a whole lot. Both the OEM and Black Onyx gaskets use chrome in that area. The area you need to see, you can't with the heads bolted to the block.
Old Oct 17, 2012 | 09:47 PM
  #381
m-chan68's Avatar
m-chan68
Yes it would. You just have a rebuilt older engine.
Old Oct 17, 2012 | 09:58 PM
  #382
run6.0run's Avatar
run6.0run
That's just wonderful. Crap, if I take the heads off, they have very good reason to void warranty. If I don't, and they aren't oem, well we all know. But I will feel stupid if I take them off and they are blue. If I take them off, shouldn't I get new gaskets anyways?
Old Oct 17, 2012 | 10:00 PM
  #383
Yahiko's Avatar
Yahiko
Anthony,
That was very good chatting on the phone. The cats did not get MY dinner.
<a href="http://imageshack.us/photo/my-images/443/dsc0060m.jpg/" target="_blank"><img src="http://imageshack.us/a/img443/7344/dsc0060m.th.jpg" border="0"/></a> But she wanted it.
The PC I was whimpering about quit again. Time for a re-build
on that I think .
I am going to look into that worm gear drive for the stand and try my
hand at making one. It does not look that hard and I think it will work.
When I do I'll see what it will take to make two if you would like.
Sean
  #384
run6.0run's Avatar
run6.0run
Guess I only have to take one off huh. They swore they are ford
Old Oct 17, 2012 | 10:03 PM
  #385
run6.0run's Avatar
run6.0run
Originally Posted by Yahiko
Anthony,
on that I think .
Sean
Absolutely!!!!!! Can u build it now?!?? Lol.
Old Oct 17, 2012 | 10:04 PM
  #386
run6.0run's Avatar
run6.0run
Are there any longevity benefits to the 20mm block?
Old Oct 17, 2012 | 10:07 PM
  #387
Yahiko's Avatar
Yahiko
I think I could build one. Need to do some research.
M-chan,
What is the hole size in the injector cup? I may know of a
scope that would fit. Just need to know the size. It would
be the old style with a ridged tube without video just a eye
piece to look in with.
Sean
Old Oct 17, 2012 | 10:14 PM
  #388
run6.0run's Avatar
run6.0run
Maybe 9/32".
Old Oct 17, 2012 | 10:16 PM
  #389
run6.0run's Avatar
run6.0run
I'm ready to pull one head, should I trash the hg even if its ford.
Old Oct 17, 2012 | 10:24 PM
  #390
BLADE35's Avatar
BLADE35
Here it is. I hope it plays
6.0 bad lifter - YouTube
Now I didnt see anyone Mention anything so I will
With the Play in the Roller in the Lifter like this How much of a preformance loss is theere as the Valve Open Duration is signifigantly reduced
Since the 6.0L is a Boosted Moter maybe the Preformance Loss is Minimal compared to a Gasser
I would guess a Gasser that did this might be in the range of a 15%-20% power Loss thats probably little High
But a Boosted Moter with an Injector setup High press like it is I would think the PCM can make up for some of that???
What do the Techs think about this???
