Engine removal pics
Old Oct 17, 2012 | 06:35 PM
  #346
run6.0run's Avatar
run6.0run
Originally Posted by MisterCMK
Are you talking about the outside edge of that seal?
Yeah, it's perfect except for that spot. Hopefully they installed it with the $250 tool.
Old Oct 17, 2012 | 06:36 PM
  #347
Yahiko's Avatar
Yahiko
From what I am reading they don't say wet or dry.
They do say 10 FT-LB
But check your info and go by that.
Sean
Old Oct 17, 2012 | 06:48 PM
  #348
BLADE35's Avatar
BLADE35
So whats the Deal is it a WEEK LATE with all the wrong Parts???
So they told you the engine would have ARP and OEM headGaskets??? even better yet ALLL OEM Gaskets?????????????
I be mad as hell for being Lied to If this^^^ is true
I take it Sean Posted the Coolant filter thread I didnt look but I do remember it
I cant beleive the Paint chips in the Cooling system Hope the coolant filter will get them before the Oil Cooler does
Old Oct 17, 2012 | 06:54 PM
  #349
run6.0run's Avatar
run6.0run
No oil pickup tube gasket. Wonderful
Old Oct 17, 2012 | 06:56 PM
  #350
run6.0run's Avatar
run6.0run
Spoke too soon. The wife found it.
Old Oct 17, 2012 | 06:58 PM
  #351
Yahiko's Avatar
Yahiko
I think I will never buy any thing from them after this.
I was watching and giving some input in the coolant filter
thread and I thought that maybe they will be ok but after this
NO way will I use them. I had even forgotten about the filter
post and when I googled there name I saw I had already been
to there web site and got to thinking and then it came to me
that it was the filter post.
Sean
Old Oct 17, 2012 | 07:06 PM
  #352
BLADE35's Avatar
BLADE35
Sean
Me too
If I was the customer and wanted specific parts I better get them especialy after Waiting this long to get the engine
Good God Black Onyics HeadGaskets might as well Pull it apart Now and Change them its going to be alot faster now then in 5K down the road on the side of the road Brokedown when the engine is in the truck
400 to ship it back OK but 700 restocking Fee what Crooks its there screwup
Old Oct 17, 2012 | 07:09 PM
  #353
Fulthrotl's Avatar
Fulthrotl
Should the connecting rods have play side to side on the crank???
yes. there is a spec, google didn't find it, but if you think about it,
there is no way to adjust this, save replacing parts that have excessive
tolerances. not enough is more of a problem than too much.
right now, i'm guessing you are in hyperobservant mode, which
given what has happend to this point, is to be expected.
a dial indicator on the side of the rod and a hard measurement
taken is the only way to tell.... .010" of an inch feels
like half a foot, especially if you are freaking out about the whole
transaction.
a cheap dial indicator at harbor freight won't let you build
the space shuttle, but it'll tell you if you are in the ballpark,
for piece of mine. i personally wouldn't worry about it.
Old Oct 17, 2012 | 07:30 PM
  #354
MisterCMK's Avatar
MisterCMK
I wouldn't worry about that. It seals around the crank.
Old Oct 17, 2012 | 07:37 PM
  #355
m-chan68's Avatar
m-chan68
So, if I understand correctly, your engine arrived with Black Onyx gaskets installed? Are you going to be pulling the heads off yourself and re-installing Ford gaskets? If not, can you take a close-up shot of your cylinder heads please?
Old Oct 17, 2012 | 07:49 PM
  #356
run6.0run's Avatar
run6.0run
I don't think they're black onyx.
Dunno if this helps. It's still upside down
Old Oct 17, 2012 | 07:58 PM
  #357
m-chan68's Avatar
m-chan68
That view helps a lot. Is that a 10mm bolt or 13mm bolt that secures the rocker arm carrier to the cylinder head? Because if it is a 10mm bolt, it looks like you have an older version engine on your hands here. Also, before doing anything else, get one of your injector hold-down "crab claws" to see if it will thread into the hole in the cylinder heads. If it's too big and won't thread in, that there's your "nail in the coffin" that you have an 18mm engine instead of the 20mm that came out of your truck. Hope this info helps.
Old Oct 17, 2012 | 08:46 PM
  #358
BLADE35's Avatar
BLADE35
Its Been a Long Pause Mike Hope he just eating Dinner and has the right engine
Old Oct 17, 2012 | 09:00 PM
  #359
m-chan68's Avatar
m-chan68
Benny, I have to admit that picture is a little hard to tell if the rocker arm carrier bolt head is a 10mm or 13mm size. What I do know though, is he does have the 20mm block from the pics he posted of his old engine. Now I'm curious to know if this engine has the correct rear cover for a manual transmission even.
Old Oct 17, 2012 | 09:03 PM
  #360
run6.0run's Avatar
run6.0run
Sorry guys. Sean called. The head on the bolt is 10 mm. Rocker carrier.
