Engine removal pics
Old Oct 13, 2012 | 12:29 AM
  #226
Yahiko's Avatar
Yahiko
To tell if you need to replace it your going to make
some measurements and I don;t know what the
tolerance should be.
Sean
Old Oct 13, 2012 | 12:40 AM
  #227
run6.0run's Avatar
run6.0run
Do lifters never spin. There's no lip machined in the bore to keep them aligned with the cam. I guess the force of the valve train keeps them straight.
Crap!!!! I've got it. The lifter on the left of cylinder #3 has up and down play in the roller. That's prob my squeak. In freakin very, very happy.
Old Oct 13, 2012 | 12:44 AM
  #228
run6.0run's Avatar
run6.0run
Here it is. I hope it plays
http://youtu.be/ixjJ7z4Xip8
Old Oct 13, 2012 | 12:47 AM
  #229
run6.0run's Avatar
run6.0run
Thx to you guys. Mchan, you called this a while ago. Dunno if you remember, but here's a HUGE attaboy to you.
Old Oct 13, 2012 | 01:06 AM
  #230
Yahiko's Avatar
Yahiko
Well you could pull the cam shaft and get a re-grind and
new lifters and put it back in service if you wanted to at
this point. Are you thinking that maybe that is what made
the holes in the pump gear?
Sean
P.S. Bed at 12:01AM PT
Old Oct 13, 2012 | 01:23 AM
  #231
run6.0run's Avatar
run6.0run
I think I was on borrowed time. Now I'm very happy I'm doing this
http://youtu.be/LdeMW-gwe-o
Old Oct 13, 2012 | 01:26 AM
  #232
run6.0run's Avatar
run6.0run
Sean
Prob huh. Do you all think pulling the engine was justified?
That cam prob isn't gonna make the cut. I hope it will tho
Old Oct 13, 2012 | 02:53 AM
  #233
run6.0run's Avatar
run6.0run
What do you guys think about this
http://www.rivercitydiesel.com/index...mart&Itemid=54
I just found a complete set of lifters new on eBay for 150. They must be junk.
Old Oct 13, 2012 | 08:08 AM
  #234
npccpartsman's Avatar
npccpartsman
I found a renamed set from a quality manufacturer at Autozone for <$10 each and they weren't junk. Their website says they don't carry 6.0 lifters but the application is correct if you search for the part number (which I can't supply since I'm not home at this moment).
Old Oct 13, 2012 | 08:11 AM
  #235
npccpartsman
The plastic retainers keep them aligned to the camshaft so they can't spin. If a roller lifter spun you'd have immediate catastrophic damage.
Old Oct 13, 2012 | 10:10 AM
  #236
run6.0run's Avatar
run6.0run
Aw man, I thought you had all those numbers memorized. Lol
Old Oct 13, 2012 | 10:11 AM
  #237
run6.0run's Avatar
run6.0run
I forgot about the plastic pieces. Ok great. Thx
Old Oct 13, 2012 | 11:17 AM
  #238
npccpartsman
Between Ford, Kubota, Massey, and Bobcat I have too many numbers to try and remember. At my age I don't even try anymore. I go through a lot of ink and printer cartridges..........
Actually I was hoping you'd find them so I wouldn't have to look them up again.
Old Oct 13, 2012 | 11:22 AM
  #239
m-chan68's Avatar
m-chan68
You know Anthony, I give you credit where credit is due. Not too many guys would have the patience to take on a repair as deep as you're into. Just out of personal interest, it's too bad you're in Kansas. Otherwise if you were willing to pay to fly me into your town, as well as lodging, I would actually be glad to give you a hand with your build. It's just that on the dealership level, a repair to this extent would not be economically feasible to most people, so we never get into one like this on the customer's dime. No, let me restate that. Not even Ford would bother. The last engine I had in for what was originally intended to be a bedplate reseal ended up with a long block on Ford's dime, as soon as I discovered there were cam lobes ground down during the disassembly process.
Old Oct 13, 2012 | 11:35 AM
  #240
m-chan68's Avatar
m-chan68
Well Anthony, if you are interested in more part numbers from Ford here they are:
4C3Z-6250-AA Camshaft
8C3Z-6C329-B Plastic Roller Lifter Guide (with 4 lifters)
I don't know the Navistar part numbers that cross reference to the two above, but you might be able to source it out if you do some searching.
