Engine removal pics
Old Oct 19, 2012 | 07:55 PM
  #511
m-chan68's Avatar
m-chan68
Originally Posted by run6.0run
I see it on the service manual. Crap,,, good save Mike!!!! Again!!! The wife is goin out to the shed to find it on the trailer while I disassemble. So there's one flange without the guide pin hole, and one with the hole?
Are you going to thank me now, or thank me later?
Step #69 of the Ford Workshop Manual Section 301-01C under engine assembly illustrates this piece very clearly.
You would have been having a really bad time if you left this piece off.
  #512
Yahiko's Avatar
Yahiko
WOW that is nice looking. Bright and shinny like the sun
A lot better than the old one that is for sure.
Sean
Old Oct 19, 2012 | 07:58 PM
  #513
run6.0run's Avatar
run6.0run
Here's the first
  #514
raptor131's Avatar
raptor131
Originally Posted by m-chan68
Stupid question. You didn't forget to install the adapter flange between the flywheel and crank, did you?
Is that the part called the "dust shield"on page 78 of the 03 coffee table book ?
Old Oct 19, 2012 | 08:01 PM
  #515
run6.0run's Avatar
run6.0run
Screw a beer, you deserve a keg. Tearing the garage apart now.
Old Oct 19, 2012 | 08:05 PM
  #516
run6.0run's Avatar
run6.0run
I'm goin out to check for myself
  #517
run6.0run's Avatar
run6.0run
Does anyone know the part #. Midway ford is open now
Old Oct 19, 2012 | 08:07 PM
  #518
m-chan68's Avatar
m-chan68
That would be it, in illustration numbers 158 and 159.
Old Oct 19, 2012 | 08:15 PM
  #519
m-chan68's Avatar
m-chan68
I can't seem to find a base part number in any illustration that I have access to. Not that it helps much, but the base part number from Ford for a flywheel is 6375 (or 6477 for the garbage dual mass flywheel). And the crankshaft base part number is 6303 if it helps much.
Old Oct 19, 2012 | 08:16 PM
  #520
run6.0run's Avatar
run6.0run
This is the old flywheel
Old Oct 19, 2012 | 08:19 PM
  #521
run6.0run's Avatar
run6.0run
My new clutch didn't have any cap in the center of the flywheel. Should it?
  #522
m-chan68's Avatar
m-chan68
What about the old crank?
Old Oct 19, 2012 | 08:37 PM
  #523
run6.0run's Avatar
run6.0run
Ok. I gave my vin to midway, they are showing two different parts, but when he clicked on the front adapter, it didn't give a part number. The rear adapter number is 3C3Z6A366BA.
Old Oct 19, 2012 | 08:39 PM
  #524
run6.0run's Avatar
run6.0run
I can't see through the old flywheel center. But I can see thru the new one.
Old Oct 19, 2012 | 08:41 PM
  #525
run6.0run's Avatar
run6.0run
Hang on. I'll get that.
