Engine removal pics
Old Nov 28, 2012 | 01:20 PM
  #1126
run6.0run's Avatar
run6.0run
Got the power steering line
The bumper for the red one looks good
Transfer case vent
That line swivels just like the old one,,,, hopefully it doesn't leak. The old one didn't drip, but it stayed wet there
Got the crossmember in
Cac is almost in
I hit a deer last year and it broke the brackets on it. I can't see spending all that $$$$$ just because of some brackets. I drilled n put screws in it. It was an imperfect science. If I ever do have to replace the cac, then fine. I used spacers to get it to sit where it needs to be
I need to get the riff raff metal tube for this. Someday I will
I've for new hoses for this ,, but I will just wait til one blows off or years to replace them
Well crap ,,, I took the radiator out before I pushed the truck up to the garage. It won't fit,,, Gotta push ur back a couple inches.
Old Nov 28, 2012 | 01:25 PM
  #1127
run6.0run's Avatar
run6.0run
Originally Posted by bismic
From what I understand, one of the stators main jobs is to help the air flow get to various parts of the engine for cooling - ie alternator, sensors, wiring, and even FICM. I doubt that you will see any negative effects for quite awhile, but many people assert that some of the mentioned components WILL fail early without the stator.
Yeah, I've heard that,,, but honestly,,,, can anyone really say the stator caused components to go out???? They break on trucks every day with stators in. I just think that we are thinking about it with the hood open. Close the hood, and that air is gonna get everywhere it needs to be. I dunno,,, but in willing to try anything once. If I gotta pull my wallet out because of it,,,,, then I will post it up and let everyone know its a bad idea. I'm ok with fessing up about mess ups.
Old Nov 28, 2012 | 01:35 PM
  #1128
2006lariat's Avatar
2006lariat
That makes You a good man!
Old Nov 28, 2012 | 01:41 PM
  #1129
Crash16's Avatar
Crash16
I have to ask, where did you get the diamond plate filler panel for the conversion on your 04?
Old Nov 28, 2012 | 02:32 PM
  #1130
run6.0run's Avatar
run6.0run
Ok guys,,,, I need help!!!!! With the key in my hand and as I hook up the battery,,,, the starter turns over????? Is t there only three studs on the starter,,,, and the hot line goes to the big one without the bare (ground) wire???? And the switched wire goes to the small stud????
Old Nov 28, 2012 | 02:42 PM
  #1131
mustang_309's Avatar
mustang_309
The small insulated wire on mine goes to the post under the large one
Old Nov 28, 2012 | 02:47 PM
  #1132
Yahiko's Avatar
Yahiko
Only the three.
The big RED on for the battery and the smaller Y/LB from the starter relay.
and a ground. Un hook the Y/LB one from starter and see if it has power with the battery
hooked and key off or in your hand.
Sean
Old Nov 28, 2012 | 02:52 PM
  #1133
run6.0run's Avatar
run6.0run
Ok lemme get caught up first. Ps cooler in
I didn't clamp em yet,,, but it should b fine for now
Snap on radkit. Very useful tool
U got almost 7 gallons of straight distilled water. Once I know it doesn't leak, I will put the elc in
It works for the power steering too. Remember I had the whole system apart. Had to vac it down a couple times before I quit hearing gurgling.
Old Nov 28, 2012 | 02:53 PM
  #1134
run6.0run's Avatar
run6.0run
Ok here is how the starter connections look
  #1135
run6.0run's Avatar
run6.0run
Is the starter wire supposed to be routed over the motor mount??
Old Nov 28, 2012 | 02:56 PM
  #1136
run6.0run's Avatar
run6.0run
I completely unhooked the starter, hooked up the battery,,,, all good. I'm gonna test them right quick.
Old Nov 28, 2012 | 02:59 PM
  #1137
run6.0run's Avatar
run6.0run
Has anyone ever had a starter go bad n do this??
Old Nov 28, 2012 | 03:13 PM
  #1138
run6.0run's Avatar
run6.0run
K,,, the wires are functioning as they should,,,, I realized I didn't have the smaller hot line on the driver side battery... It's on now,,, I'm gonna put the starter back in,,, but my glow plugs aren't making any noise
Old Nov 28, 2012 | 03:17 PM
  #1139
raptor131's Avatar
raptor131
Glow plugs making noise, you mean the injectors buzz? If not check ficm connectors make sure they are seated
Old Nov 28, 2012 | 03:24 PM
  #1140
raptor131's Avatar
raptor131
BTW, if you are going to start it for the first time is someone manning the video camera? We gotta have video......please!
