Engine removal pics
Old Oct 19, 2012 | 08:44 PM
  #526
run6.0run's Avatar
run6.0run
It's one solid peice
Old Oct 19, 2012 | 08:47 PM
  #527
run6.0run's Avatar
run6.0run
The parts guy thought it might be a dual mass thing??? He wasn't showing a part number for what I was asking for. Any chance it's not on a single mass??
  #528
m-chan68's Avatar
m-chan68
You're not supposed to be able to see through the center of the old flywheel. That looks perfectly normal to me. As far as why you can see through the center of your new flywheel, the only answer I can give you is because you're new flywheel is not OEM. But more importantly, where did that adapter plate end up? Do you at least remember when you removed the rear cover on your old engine? You would've needed to remove that piece before being able to remove the rear cover.
Old Oct 19, 2012 | 08:50 PM
  #529
m-chan68's Avatar
m-chan68
NOPE. Go to page #15 of the 2003.25 6.0L Coffee Table Book. Illustration #23 appears identical to what came out of your truck, so I'm 100% sure your truck has always had a single mass flywheel.
Old Oct 19, 2012 | 08:51 PM
  #530
run6.0run's Avatar
run6.0run
Here's my old rear cover
Old Oct 19, 2012 | 08:53 PM
  #531
run6.0run's Avatar
run6.0run
I meant that is there any chance a single mass setup doesn't have it???
Old Oct 19, 2012 | 08:54 PM
  #532
run6.0run's Avatar
run6.0run
We're still looking. Crap!!!!!
Old Oct 19, 2012 | 08:58 PM
  #533
run6.0run's Avatar
run6.0run
Would it have came off easily after the flywheel?
Old Oct 19, 2012 | 08:59 PM
  #534
m-chan68's Avatar
m-chan68
Yes, there is supposed to be another piece that goes between what you have there, and the flywheel.
  #535
raptor131's Avatar
raptor131
It says you would have needed a "finger type" puller to remove
Old Oct 19, 2012 | 09:00 PM
  #536
run6.0run's Avatar
run6.0run
Is it steel???
Old Oct 19, 2012 | 09:01 PM
  #537
raptor131's Avatar
raptor131
Go here download the coffee book and go to page 78 https://www.ford-trucks.com/ford-man...eTableBook.pdf
  #538
m-chan68's Avatar
m-chan68
In my experience, that piece would just require a little prying before it comes off the dowel. I'm finding it difficult to believe that you can't actually remember removing it.
  #539
run6.0run's Avatar
run6.0run
So one of these except with a hole for the guide pin
Old Oct 19, 2012 | 09:03 PM
  #540
run6.0run's Avatar
run6.0run
I haven't been drunk, promise.
