Engine removal pics
Old Oct 3, 2012 | 11:39 PM
run6.0run's Avatar
run6.0run
Engine removal pics
Just popped the hood
Got the bumper off
Had to take a trip n get the equipment
Removed the ac condenser, headlights n support, ps cooler n who knows what else
Just another pic. Got the batteries out. I wanted to remove as much as I can to allow me to stand as close as possible to the engine
Removed radiator, shroud , cac n tubes, air filter plumbing, coolant bottle.
Side view
Got the top support out, I have never removed this. Wow, it opens it up huh
Got the fan n stator off
Just another pic
Belt, intake elbow, alternator, oil n fuel filter housing n upper n lower rad hoses removed
Another pic
Another one
It's quitting time
I'm trying to get better and give some back to FTE by posting stuff, hopefully someone will get something outta it. There will b more to come. I hope to document the entire process. I wanted to get more indepth about the process, but it's hard when parts are flying.
Old Oct 4, 2012 | 01:41 AM
daddykitty's Avatar
daddykitty
what are the braided lines right below the tstat housing for?
Old Oct 4, 2012 | 01:55 AM
run6.0run's Avatar
run6.0run
Coolant recirculating kit. I'm not putting it back on. One of The braided lines had some belts break and the line was leaking bad. That kit sux to fix,,,,
Old Oct 4, 2012 | 05:46 AM
mustang_309's Avatar
mustang_309
Very cool, thank you for documenting with photos and sharing them with us.
Old Oct 4, 2012 | 08:39 AM
crewsd's Avatar
crewsd
motor removal
Why are you having to remove?
Old Oct 4, 2012 | 10:33 AM
run6.0run's Avatar
run6.0run
I think a lifter gave way. I should know tonight or tomorrow what went wrong. The last pic is how it looks now. I'm gonna keep documenting.
Old Oct 4, 2012 | 10:34 AM
run6.0run's Avatar
run6.0run
300 watt light bulbs make it like daytime huh. Lol
Old Oct 4, 2012 | 10:48 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you don't mind me asking... how are you going to hook it up to the lift? I've only see people use the rotunda lifting bracket, so it'd be great to see how you get it out.
That thing is pretty by the way, it looks really clean, no nasty mess all over the intake or running down the front cover. Sucks that it STB.
Old Oct 4, 2012 | 11:05 AM
run6.0run's Avatar
run6.0run
I doubt I will use that balancing tool. I'm planning on bolting a plate into the turbo pedistal spot. I also need to drop the transfer case n trans to seal up a leak at the joint of the two.
Old Oct 4, 2012 | 11:55 AM
run6.0run's Avatar
run6.0run
Wow u noticed how clean it is. I kinda take pride in keeping it clean. I keep telling performance machine mfg (pmm). That my existing engine has no oil leaks(dry bell housing) and I will want a warranty claim if it leaks. It's so easy to keep up on it if its clean. Let alone see a potential problem quickly.
Old Oct 4, 2012 | 12:47 PM
Yahiko's Avatar
Yahiko
Run6.0run,
I must agree it is so much easier to find a
leak if the space it clean to start with. You
look at some photos and think that they just
ran the Baja 1000 there is so much dirt and dust.
Thank you for sharing in the operation.
Here is a cold one or two for you
Sean
Old Oct 4, 2012 | 01:14 PM
m-chan68's Avatar
m-chan68
Is this work being done in your driveway? How on earth do you have the time to do this yourself? Looking at your photos only reminds me all the more clearly why I lift cabs to replace engines on these trucks (and I have replaced more than my share).
Old Oct 4, 2012 | 02:04 PM
run6.0run's Avatar
run6.0run
I drive this for a living, so when it's down, I'm down. I didn't think it was too bad removing the front. I've never done it before and it is a very different perspective looking at it from there. It was cool to take the stator bolts out like that. I didn't have to get on the ground to take the bottom ones out. Very nice. I also discovered that my cac has been compromised by the power steering cooler. That sux. There are some spots that it wore holes in it.
Old Oct 4, 2012 | 06:56 PM
Piolet's Avatar
Piolet
Subscribing to this one and sending reps in advance of your efforts. (Edit: I'm in rep jail )
I know I can get all the stuff on and around the engine disconnected/removed but I have no idea how to unhook the engine from the tranny and then what tricks might be involved in getting it back in and lined up correctly.
Nice job and there'll never be too many pics.
Old Oct 4, 2012 | 07:18 PM
UGA33's Avatar
UGA33
Looks just like my route. I was lucky that this truck I'm doing a motor on is 2-wheel drive, so I pulled the engine and trans all at once. Don't forget the trans cooler line that bolts to the engine down under the ac compressor. Hope that keeps you from doing what I did.
