Engine removal pics
Old Oct 19, 2012 | 06:48 PM
  #496
run6.0run's Avatar
run6.0run
I got it to work. I think I'm looking for stuff wrong huh.
Made me a flywheel holder.
Any pointers for this??? Should I b removing the little stud before installing the flywheel?
Old Oct 19, 2012 | 06:49 PM
  #497
UGA33's Avatar
UGA33
I always like to put a dab of RTV silicone under the HPOP cover where the rear cover and block meet up at the back of the cover.
Old Oct 19, 2012 | 06:53 PM
  #498
m-chan68's Avatar
m-chan68
Stupid question. You didn't forget to install the adapter flange between the flywheel and crank, did you?
Old Oct 19, 2012 | 07:11 PM
  #499
wulfman's Avatar
wulfman
Originally Posted by MisterCMK
It looks like the PMM warranty requires you to install a new oil cooler.
Mr CMK is right they say you have to present a receipt for the new one or warentty is void
Old Oct 19, 2012 | 07:15 PM
  #500
m-chan68's Avatar
m-chan68
F*** that!!! For the cost of this purchase, I'm actually amazed a new one didn't come with this engine!!!
Old Oct 19, 2012 | 07:31 PM
  #501
run6.0run's Avatar
run6.0run
Not a stupid question. Um????? I had a flange that didn't have a hole for the guide stud. I put that on after the flywheel. ****???? I don't think I did. Do you, or anyone have a pic of it???? Crap,,,, thank god it ain't welded. Lol
Old Oct 19, 2012 | 07:34 PM
  #502
run6.0run's Avatar
run6.0run
I have some more pics. N a sec.
Old Oct 19, 2012 | 07:36 PM
  #503
m-chan68's Avatar
m-chan68
I know it sucks, but why don't you just pull the flywheel off and post pics of all the parts in the order you install it onto the crank before you button it up? The reason for this, is because I have heard of several techs that have forgotten to install that piece only to do damage once it was all buttoned up. And I know that would just suck royally for you if you did this. Even more so on a manual transmission truck.
Old Oct 19, 2012 | 07:37 PM
  #504
run6.0run's Avatar
run6.0run
Well, none that show before installing the flywheel.
There were papers in it that said to make sure the fingers weren't angled. I don't think they are.
Old Oct 19, 2012 | 07:38 PM
  #505
run6.0run's Avatar
run6.0run
Will do!!!! Gimme a sec,,, u stayin up 4 a bit???
Old Oct 19, 2012 | 07:40 PM
  #506
run6.0run's Avatar
run6.0run
I bolted it to the plate you kinda see in this pic. Could the flange be stuck to my old flywheel?
Old Oct 19, 2012 | 07:42 PM
  #507
m-chan68's Avatar
m-chan68
I'm going to be up for quite a while.
By the way, that clutch looks like an interesting piece. At least it doesn't have to be placed in a bearing press to have the fingers "reset" like the original ones do, and the ones used on Ford Rangers.
Old Oct 19, 2012 | 07:44 PM
  #508
run6.0run's Avatar
run6.0run
I see it on the service manual. Crap,,, good save Mike!!!! Again!!! The wife is goin out to the shed to find it on the trailer while I disassemble. So there's one flange without the guide pin hole, and one with the hole?
Old Oct 19, 2012 | 07:47 PM
  #509
Yahiko's Avatar
Yahiko
I agree ^^^^^^^^^^
On other things how are things going ?
Sean
Old Oct 19, 2012 | 07:54 PM
  #510
run6.0run's Avatar
run6.0run
She didn't find it. I'm guessing they're on all of them. Both flywheels are single mass flywheels. I haven't lost any parts,,,,, until now.
