Engine removal pics
Old Oct 18, 2012 | 07:57 PM
  #451
Yahiko's Avatar
Yahiko
Originally Posted by Fulthrotl
if i were you, i'd stop about 8 pm, have some dinner, and get
a good nights sleep..... doing what i do, when i've had burn it
to the waterline projects, you are working with high voltage
and there is a brutally darwinian learning curve there....
low voltage is open casket, high voltage is closed casket, by the way.
~~~~~~~~~~~~~~~~~~snip~~~~~~~~~~~~~~~~~~~~~
and we are gonna get a good test on VR gaskets.... i'd do what mark
suggests, and put a pressure guage on the degas bottle, and see how
your pressure in there runs... long before those head gaskets go
away, they will be bleeding pressure into the coolant..... and you'll
have time to make a strategy, instead of being on donner pass on
a hook....
Some very good advice. Get some rest tonight and start fresh in the AM.
Not 1,2,3,4 even 5AM enjoy some good sleep.
Sean
Old Oct 18, 2012 | 08:17 PM
  #452
run6.0run's Avatar
run6.0run
More progress.
Got new bolts n spacers,,, they were cheap. Anti seize them also
Went ahead n put the ficm brackets on
Dipstick in. There was the oring for it. Wow
I could feel it bottom out
The tube on the ebp was very rusted at the nuts
Got a new one. What are those yellow things????
Old Oct 18, 2012 | 08:19 PM
  #453
run6.0run's Avatar
run6.0run
I might've just been too cautious while threading the inj clamps in. I think they are good. 26 sure felt like a lot. Thought my wrench was broken, guess not, cause the new one is the same. Lol. Now I have 2.
Old Oct 18, 2012 | 08:22 PM
  #454
run6.0run's Avatar
run6.0run
that is reasonable. you'll know all you need to know a while before
that milestone, i suspect.
breathe in and breathe out. you've been pretty wrapped on this
for a while now.... and rushing at this point is where most of us
screw up... we are tired, annoyed, and just want it DONE.
i've had to learn to pace things, and that is where you are at right
now.... get some rest, tomorrow is another day.
a hook....
This isn't the first post you've put up that explained exactly how I'm feeling. I can't stop. It feels downhill now. Lol.
Old Oct 18, 2012 | 08:23 PM
  #455
OxJaw's Avatar
OxJaw
Tempting
Can't tell you how many times I have thought about doing this very thing. The engine compartment in these trucks are hard to work in. Especially when you are back in by the firewall.
Old Oct 18, 2012 | 08:27 PM
  #456
m-chan68's Avatar
m-chan68
And that very statement is exactly why I lift the cabs to do any repairs that involve removal of cylinder heads, and/or the engine itself.
Old Oct 18, 2012 | 09:32 PM
  #457
Yahiko's Avatar
Yahiko
Anthony,
They are used to cap the tube to keep dust and other crap out.
I keep a few sets of different sizes in my tool box.
Sean
Old Oct 18, 2012 | 09:47 PM
  #458
run6.0run's Avatar
run6.0run
Had to transfer the stator bolts, mounting bolts, or whatever there called. Lol
And the little bolt that the batt cables attach to
Got the coolant pump n pulley torqued on. Didnt use any sealant. Just the oring. Sure glad that's red. Lol
Crap, already scratched it.
Got new bolts for the crank pulley.
Got the other pulleys on
That sum btch was nasty. It's never been changed
I forgot to take a pic of it cleaned. I sanded it. At least it's easy to replace if my numbers are off. I might replace it ne ways.
Old Oct 18, 2012 | 09:49 PM
  #459
daddykitty's Avatar
daddykitty
they can also be used for nipples to feed baby kitties
Old Oct 18, 2012 | 09:51 PM
  #460
run6.0run's Avatar
run6.0run
What is that piece in the middle of the clutch fork? I ordered one, but will a new one come with the south bend clutch?
Old Oct 18, 2012 | 09:52 PM
  #461
daddykitty's Avatar
daddykitty
on your water pump wrench...you can dip it in plasti-dip if you don't want to scratch your fresh paint
Old Oct 18, 2012 | 09:55 PM
  #462
m-chan68's Avatar
m-chan68
The throwout bearing.
Old Oct 18, 2012 | 11:08 PM
  #463
run6.0run's Avatar
run6.0run
Great idea.
Old Oct 18, 2012 | 11:19 PM
  #464
run6.0run's Avatar
run6.0run
I should've looked closer online at the clutch I'm getting. It comes with all of it, plus an alignment tool and a solid flywheel. Very nice. Thx Mike.
Old Oct 18, 2012 | 11:27 PM
  #465
run6.0run's Avatar
run6.0run
Okay, but does yours use a TX-40 or TX-45? A TX-40 WILL fit a later model hold-down but will have some slack in the bolt head. I guess the real question is if a TX-45 will fit or not? If the answer is no, then your truck was originally equipped with an earlier build cylinder head. If the answer is yes (which I believe it is), you have a 20mm cylinder head (I remember you pulling out the four 13mm rocker arm carrier box bolts).
Yeah the old one is 20. The t40 was a bit too sloppy.
K I'm gonna give it a rest. I'm done for today. Thx everybody
