Engine removal pics
Old Oct 13, 2012 | 11:46 AM
  #241
run6.0run's Avatar
run6.0run
I just found this kit, it looks like it comes with the lifters and cam. Whatcha think
http://rpmmachine.com/engine-kits/?v...ype=Master+Kit
Old Oct 13, 2012 | 11:50 AM
  #242
run6.0run's Avatar
run6.0run
Originally Posted by m-chan68
The ideal engine stand to have used for this engine would've been the one manufactured by Norco like this one: 2,000 Lbs. Engine Stand - NORCO Industries
using these adapters:
Engine Mounting Adapter - Made in USA - NORCO Industries
This way, you could remove both the front and rear engine covers on the stand.
However in absence of that, you may just end up having to lay the engine flat on the ground upside down to gain access to the rear engine cover.
Crap, those are expensive. I might try and build one.
Old Oct 13, 2012 | 11:58 AM
  #243
m-chan68's Avatar
m-chan68
How good of a MIG welder are you? A lot of it is just tubular steel, along with some good set of heavy duty casters. The hardest most complex part of making one of these will be the rotating assembly that enables the engine to be flipped upside down
Old Oct 13, 2012 | 12:03 PM
  #244
run6.0run's Avatar
run6.0run
You know Anthony, I give you credit where credit is due. Not too many guys would have the patience to take on a repair as deep as you're into. Just out of personal interest, it's too bad you're in Kansas. Otherwise if you were willing to pay to fly me into your town, as well as lodging, I would actually be glad to give you a hand with your build. It's just that on the dealership level, a repair to this extent would not be economically feasible to most people, so we never get into one like this on the customer's dime. No, let me restate that. Not even Ford would bother. The last engine I had in for what was originally intended to be a bedplate reseal ended up with a long block on Ford's dime, as soon as I discovered there were cam lobes ground down during the disassembly process.
How nice of a hotel do you want. $100, $200, we even have $3000 rooms downtown. Holy crud, what an offer. I'm freaking out!!!???!!! That's awesome. I couldn't imagine the amount of info I would receive. I'd have to video that. I'd be asking questions. B like one of those annoying kids that keeps asking "why, why". Lol. The amount of time you, Sean, partsman, and everyone else has spent to help me with the info is priceless. You guys are teaching me to fish, you know the phrase,,,.
I just found out, they did get my engine out the door Friday, it left Atlanta at midnight.
Old Oct 13, 2012 | 12:04 PM
  #245
run6.0run's Avatar
run6.0run
Btw, not Kansas, I'm in kc mo. That's Missouri. We're tiger fans here. Lol.
Old Oct 13, 2012 | 12:10 PM
  #246
Piolet's Avatar
Piolet
...... if you were willing to pay to fly me into your town, as well as lodging, I would actually be glad to give you a hand with your build ....
LOL As soon as I saw that I looked up the cost of a plane ticket from Toronto to Boston MA. I have an extra bedroom with its own half bathroom and there's too much stuff to even mention as far as sightseeing and tourism goes around the NH and MA area .
Be right back. I'm heading out to buy my engine hoist right now .....................
  #247
run6.0run's Avatar
run6.0run
I have a fairly nice Hobart, do you think it would work with two tubes, one inserted into the other, like the engine stand. I'm sure it would b a pain to spin, but I was thinking about using the hoist, with a fat strap wrapped around and hooked to itself and slide it as the engine spins. Hard to explain. I was planning on spinning my new engine like this to do the oil pans. Its quite a bit heavier with both heads on, which they are torqued on the new engine.
Old Oct 13, 2012 | 12:17 PM
  #248
run6.0run's Avatar
run6.0run
Ok, rookie question, with the rear cover off, is it a crank bearing that is visible at the outer seal on the rear? I only remember one seal. Is the rear main and the rear crank seal two separate seals? It was late and I can't remember.
Old Oct 13, 2012 | 12:19 PM
  #249
run6.0run's Avatar
run6.0run
I mean in front of the adapter, at the engine block, bed plate. Is that the rear main, or a crank bearing?
Old Oct 13, 2012 | 12:26 PM
  #250
run6.0run's Avatar
run6.0run
This is gonna be a very, very long thread. I'm gonna keep on and show the installation of the new engine, building the stand, and the rebuild if the old engine. I was terrified of the crank seals, not so much anymore, it's just money for the tools. Now, I'm being concerned about removing the pistons. I've just never done it before. I think I learn fairly quick, but I don't want to learn it the wrong way.
Hopefully, others out there will get some confidence out of this.
Old Oct 13, 2012 | 12:30 PM
  #251
m-chan68's Avatar
m-chan68
Yes, that is the rear main seal that is installed into the rear engine cover.
Old Oct 13, 2012 | 12:32 PM
  #252
m-chan68's Avatar
m-chan68
There's no rocket science to that either. Just use good practices like marking the orientation of how they are to be installed into the block. Be mindful of the piston cooling jets too, during removal.
Old Oct 13, 2012 | 12:41 PM
  #253
run6.0run's Avatar
run6.0run
So is the rear crank seal, and rear main seal, one and the same.
Old Oct 13, 2012 | 12:43 PM
  #254
m-chan68's Avatar
m-chan68
Yes it is.
Old Oct 13, 2012 | 12:44 PM
  #255
run6.0run's Avatar
run6.0run
I'm not with the truck right now. Can't remember if there were two seals in the adapter bore on the rear cover
