Engine removal pics
Old Oct 19, 2012 | 01:49 AM
  #466
MisterCMK's Avatar
MisterCMK
Leave the fan stator off. Much more room to work with. You will have to strap up the fan clutch wire.
Old Oct 19, 2012 | 08:16 AM
  #467
run6.0run's Avatar
run6.0run
I was actually thinking about cutting a couple chunks outta it.
I'm having a very hard time here. Putting that engine in really doesnt feel like the right thing to do. The dirty pistons really are concerning me. What else is used junk??? I could rebuild mine myself, and know exactly what I have. I don't give a crap about any warranty, if its built right.
Old Oct 19, 2012 | 10:09 AM
  #468
Yahiko's Avatar
Yahiko
Cat got me up early he wanted out of the room. One heck of an
alarm clock.
The tops of the pistons are very hard to clean and so long as the
groves have been "cleaned" and new rings fitted they should be ok.
I have reused then many times and all I do it check the dimensions
to the chart and do the needed work then the old one are ok. And that
is with a small airplane. They should be ok.
Can't think of much more right now.
Sean sleep drinking
Old Oct 19, 2012 | 10:26 AM
  #469
MisterCMK's Avatar
MisterCMK
That is all well and good except on their website it says that they use NEW .20 over pistons and rings.
Old Oct 19, 2012 | 10:31 AM
  #470
run6.0run's Avatar
run6.0run
Their website says the pistons should b new
Old Oct 19, 2012 | 10:43 AM
  #471
Yahiko's Avatar
Yahiko
Now I did not read THAT but I did not really spend time on there site.
That is a problem. New is just that new. Not reconditioned or flat out
used.
Sean
Old Oct 19, 2012 | 12:54 PM
  #472
UGA33's Avatar
UGA33
One I put in had new pistons.
Old Oct 19, 2012 | 12:55 PM
  #473
UGA33's Avatar
UGA33
But it was a short block and would have been easily noticed. Sucks you are running into all these issues.
Old Oct 19, 2012 | 01:44 PM
  #474
run6.0run's Avatar
run6.0run
Either way, there's more to do. I need to modify my lifting plate to allow me to install the oc n hpop out of the truck. Here's it marked
I'm sure most of you have cut 1/2" steel with a 4" angle grinder. It's fun. Here's the casualties.
So far so good
Very cool. It might work. I just hope it doesn't affect the strength
Old Oct 19, 2012 | 02:01 PM
  #475
MisterCMK's Avatar
MisterCMK
Why not use the lifting eyes that are already on the motor?
Old Oct 19, 2012 | 02:03 PM
  #476
run6.0run's Avatar
run6.0run
It holds
Gp control module.
Hpop, With no gaskets for it. Hard to believe.
The famous updated stc fitting. Btw, is the updated part still called stc??? There's no snap to it. Lol
This is the feed for the hpop from under the oil cooler.
Off to the dealer
Old Oct 19, 2012 | 02:08 PM
  #477
MisterCMK's Avatar
MisterCMK
Do yourself a favor and leave the stator off of the engine. Much more room under there.
Old Oct 19, 2012 | 02:36 PM
  #478
run6.0run's Avatar
run6.0run
This is my parts washer
Getting ready to clean the oc housing
I took a couple times before I learned to dedicate a drain pan to the oil cooler. She's a messy girl. Lol
Separating the housing from the oc itself
Success
Ok if any of you know, would you tell me which of these are the output? I'd like to back flush it. There's nothing wrong with it. Deltas were fine.
Well, the dealer doesn't have the hpop gaskets, but they do have the stc kit. 40 for the stc, or 20 for the orings alone. Aren't they normally 60-80??? I guess I'm getting another updated stc. Couldn't hurt.
Old Oct 19, 2012 | 02:41 PM
  #479
MisterCMK's Avatar
MisterCMK
It looks like the PMM warranty requires you to install a new oil cooler.
Old Oct 19, 2012 | 02:48 PM
  #480
m-chan68's Avatar
m-chan68
You may want to replace the oil pressure switch and EOT sensor. What you're doing there is the exact reason why they fail either immediately, or shortly after re-installation.
