Engine removal pics
Old Oct 14, 2012 | 09:52 PM
  #286
run6.0run's Avatar
run6.0run
Originally Posted by UGA33
run6.0run, I have the Performance Machine & MFG short block back together and in the truck. I have put 30 miles on it and so far so good. Hope your project goes smoothly.
X2 on Sean's post. I dunno how to put those party guys on mobile. Lol. Congrats on the job. Did yours have the front n rear covers installed when u got it?
Old Oct 14, 2012 | 10:03 PM
  #287
Yahiko's Avatar
Yahiko
Here is how to do this :- bigparty
Just remove the space between the :-_bigparty
Where I put the _
Sean
Old Oct 14, 2012 | 10:09 PM
  #288
m-chan68's Avatar
m-chan68
So Anthony, what exactly are you going to do with your existing engine? As far as what I've seen in the pics you've posted, the only "bad" parts I see are the roller lifters, oil pump gerotor gears and maybe the cam. The rest almost like like they are re-usable with just new gaskets and seals. Are you going to build your own "Black Mamba" spec 500 bhp 6.0L engine?
Old Oct 14, 2012 | 10:13 PM
  #289
daddykitty's Avatar
daddykitty
this forum needs more smilies...cheezits is still funny as heck
Old Oct 14, 2012 | 10:22 PM
  #290
m-chan68's Avatar
m-chan68
You know Anthony, if you ever do find yourself up in my neck of the woods (and logging the kind of mileage you do, I wouldn't be surprised if it's sooner than later), you HAVE TO stop by for a beer and get together or two. Letting me drive your truck would be cool too. I would be very interested to see how one of these trucks drives with that kind of miles on it.
Old Oct 14, 2012 | 10:44 PM
  #291
run6.0run's Avatar
run6.0run
No sweat,,, are you in Toronto??? I can come and let you drive us to have a beer or 10. Lol. I was thru there prob 20 times this year. I'm gonna make it to Sean's in Tacoma also. Don't doubt it guys, we will meet up.
As far as the engine,,, I am not sure, holy crap those high performance internal engine parts are expensive. I'd like to build it big n bad,,, but it would b about 15 grand more. I've been looking online for a inexpensive truck with a bad engine. If you all know of one, lemme know.
I'm wondering if I should get everything cleaned and buy the parts, then reassemble the engine when I need it. Road builders (the local shop) said they used to leave the valve springs unattached when storing on their race engines. Stuff like that. What do you all think?
Old Oct 14, 2012 | 10:45 PM
  #292
run6.0run's Avatar
run6.0run
Where I put the _
Sean
Old Oct 14, 2012 | 10:46 PM
  #293
run6.0run's Avatar
run6.0run
Haha. Cool it worked
Old Oct 14, 2012 | 10:47 PM
  #294
run6.0run's Avatar
run6.0run
Just reread that urs was a shortblock
Old Oct 15, 2012 | 12:52 AM
  #295
Yahiko's Avatar
Yahiko
Anthony,
Does the new engine come with the glow plugs installed ?
If they are not in yet you could after you pressure prime it
turn it by hand with a wrench and your would be able to
tell that it's moving oil when the oil pressure switch closes
and your meter goes from open circuit to a closed one.
BTW I am just tossing ideas out . If the plugs are in I would not bother
trying. Just do a pressure feed at the test port.
Sean
Old Oct 15, 2012 | 09:05 PM
  #296
run6.0run's Avatar
run6.0run
I was building a deck next door. No work on the truck. But no on the glow plugs. I think I'm using mine. Will the oil pump, pump oil even at very slow speeds(stupid question prob). That would work to spin it by hand. Maybe I could leave the pressure switch out and at least crank it until oil comes out, then use the dvm. Could 5 psi be obtained by hand? Dunno.
Old Oct 15, 2012 | 09:07 PM
  #297
run6.0run's Avatar
run6.0run
Oh you said after I pressure prime it, is there something inexpensive that I could use to pressure prime it. Hudson sprayer???? Or something.
Old Oct 15, 2012 | 09:13 PM
  #298
Yahiko's Avatar
Yahiko
I think a yard spray tank you can get at Home Depot
would do the job with some simple fittings.
Sean
Old Oct 15, 2012 | 09:30 PM
  #299
m-chan68's Avatar
m-chan68
You know Anthony, in all these years that I've been active on forums helping out owners of these beasts, I must say that you are the first one that I've come across that actually went through the trouble of tearing your engine down the to cam not only to confirm my initial diagnosis (that you were heartbroken to read at the time too), but to actually follow through with the repair. For this reason, I am actually very interested in seeing the outcome of this.
By the way, are you going to be installing eight new glow plugs? I sure hope so. We all know how easily just one broken glow plug will take a piston with it, right?
Old Oct 16, 2012 | 01:42 AM
  #300
King-bRanch's Avatar
King-bRanch
Stumbled upon this & read all 20 pages straight through just now...
Rep's added for taking the time to show all of us this & proving yourself (as well as m-chan) correct
It is truly awesome to see 1 of these beasts all apart & dont hate me for this....but iam glad iam not the 1 doing/paying for all this.
Good luck w/all & ill be following to the end
