Engine removal pics
Oct 12, 2012 | 10:58 PM
I did this very carefully. Couldn't grab it with my fingers.
What do you suggest I mark them with
Oct 12, 2012 | 11:00 PM
The other method would be to remove the entire front cover with the gears inside, if you are that afraid to touch them.
Oct 12, 2012 | 11:04 PM
Sharpie works. Prob rub off easily tho
Oct 12, 2012 | 11:06 PM
I know, I know, I'm a freakin rookie, prob bein too cautious huh.
Oct 12, 2012 | 11:08 PM
Oct 12, 2012 | 11:17 PM
Scratches on very outside of big gyro
Couple deep scratches
More scratches n holes.
Inner gear has holes all the way around
Oct 12, 2012 | 11:20 PM
Get your 12mm allen key and remove the oil pressure regulator for a closer look to see if any foreign debris made its way through.
You can expect scratches because the oil has not
been through the filter yet.
The holes are interesting. I wonder what the reason is.
Sean
Oct 12, 2012 | 11:40 PM
Will the motor mount on one side (if I bolt my other hoist to one side) hold? Those bolts aren't very big.
Oct 12, 2012 | 11:51 PM
Oct 12, 2012 | 11:52 PM
I'm hanging it from the hoist. Then maybe reinstalling the stand after removing the rear cover
Oct 12, 2012 | 11:55 PM
I've gotta get one of those. Very nice. Bout to remove the rear cover
Oct 13, 2012 | 12:11 AM
I'm into it now.
Got brave. Front cover
We hung the engine to remove the rear cover
Freakin nasty stuff
Got it off
YES, I'm holding a lifter,,,
Oct 13, 2012 | 12:18 AM
Quote:
Originally Posted by
m-chan68
So the holes aren't normal
Oct 13, 2012 | 12:20 AM
Yahiko
Sean
New oil pump??????
