- Yet another intake gasket question...
- 351M=400M By Simply Changing Crankshaft?
- $#%@!*& Intake gasket!!!
- rocker ams and push rods
- engine swap
- Looking
- Piston Rod movement
- problems installing new distributor-please help
- 351 C alloy block
- 302C vs 351C H. balancer
- 400 valve differences
- oil pan
- Coil 400m
- Best Carb?
- 351m/400 flywheel interchange?
- External oil line, how much pressure difference?
- 4.9 liter straight six automatic or 84 with 351 manual.
- What octane/type of fuel is needed with quench heads at 10.7:1?
- transplanted 351M400 problem
- just wondering..........
- 351c heads
- Floating pins?
- rear main seal
- will 400 heads fit on 351
- Head porting
- Did the factory mess up?
- intake torque spec.
- 351m - 400
- 78 bronco hp/torque
- do i have a blown motor
