- Harmonic balancer bolt
- valve cover question
- Variable oil pressure
- Can a 351-400 make "That Much HP" ??
- Weiand #8310 intake manifold
- Replacing rear main seal
- Build Plan: Too Much Cam?
- 400 build compression, cam, piston selection
- Easy mods for HP gain
- Need Engine Asap!!!!!!
- WWWHHYYYY the poor mileage on propane
- my 400 isn't working right
- Zollner pistons?
- Engine Swap, Wild for Mild(er)
- Strange noise from crankcase and puffs of smoke
- 351C vs 302
- 400 cylinder wall thickness
- pro comp (chi copy) heads
- Camshaft ID
- 351m to a 400?
- Lifters locking up?
- Oil pan question
- Deck Height - Intake fit
- Is a 351W intake manifold adaptable?
- Multi-groove to single groove valve?
- Is this common w/351Measlys, or just mine?!
- 6.6/400 power gains
- 351C vs. 351M
- Headers
- Ping = too much or too little advance?
