- Problem solved! Vacuum leak. Don't let this happen to you!!
- egr valve , disconnect or leave alone ?
- 400 valve cover gaskets
- stock HP and torque 351M 79 ?
- New carb bolt on
- 79 351M; mods to run on propane?
- Edelbrock or Weiand Intake?
- how many qts of oil
- 400 piston
- 78 351M vacuum routing
- poor idling
- Intake/ exhaust valve stem seals different or the same???
- 400 Engine kit On-line, build your own kit
- cam wipeout during break in Q:
- want more peformance 351 M
- aussie and stock 400 heads details!
- intake manifolds
- 351m-400
- who makes boss 302 pistons?
- too much clearance?
- Sweet Ignition Combos Anyone????
- egr intake or not?
- Help lost with tuning adjustments
- cam selection
- New 302 BOSS block & intake FYI
- engine misses
- radiator : top hose hot, bottom hose cold!?!
- 351M front crankseal/main seal
- Cam question
- another 335 set up fer me
