- 351m -cracked water jackets
- PCV question
- Cloyes Timing Chains
- What is different from a clutch in a 351m and a 400?
- Has anyone used shorty headers in 78-79 4x4
- 4160 holley for 400
- 400 cam? valve train problems?
- had enough!!!!
- internal, external, SFI fluid damper???
- 351m/400 valve train
- Casting Number Help
- aftermarket hei dist question
- 400 timing question
- Building News
- cheap horsepower
- how much coolant?
- Bolt pattern on a 351C
- Badger Flat Tops and CR Quesitons
- Flywheel question
- 351 M cylinder bore
- 351c aluminum heads
- Question on intakes
- Replacing crank or rebuild engine?
- predetonation trouble!!!!
- Gear drive for 400 anybody?
- Help with total emissions removal PLEASE!
- 1970 to 1987 351 swap
- Vaccum Diagrams
- vacuum advance
- 351m smog crap
