- 400 vs 460 for those who have tried both.
- 351C Problems
- Torque to yield head bolts...?
- Did my 400 die??? Oil issue
- 400 Ford stroker kit
- timing chain cover
- problem setting lifter preload
- Spark Port On 78 Carb
- Gas Milage
- Torque specs for a 400 motor
- Timing Pointers and other Odd Parts
- Valve adjustment 351 c
- 400 with a forged crank?
- Tall valve covers
- 400 head bolt torque specs
- Flywheel Diameter
- cleveland heads 2V valves
- My 400 build results-opinions requested!!
- 400 vs 351c 2V heads
- Are you suppose to widen spark plug gap?
- Cleaned up heads...
- polishing heads-etc
- i wanna make a 351M run good opinions please!
- distributer stuck
- 351m main bearing oil modification
- Lost my head rockers and push rods after headwork
- Stock Distributor
- water pump pulley question
- 400 in '49 Ford F3
- 400 woke up
