- ARRGH! No power!
- Spread Bore Spacer
- What yall think of the D3ZE HEADS 351cj
- Rebuild question
- Rebuild question
- Factory Camshaft Specs
- 78-79 351M engine specs
- Help: 400cid "Mysterious Oil Leak"
- 351M Oiling MOD
- looking for 351m 4bl intake
- Stock Oil Pressure Sending Unit Mounting
- Motorcraft 2100 float adjustment
- Good Fuel Pressure
- Explain to me why my timing changes every time I start my truck?
- crankshaft weight
- falcon&r dowty,pk you home
- Overheating Issues
- 400 bearing eaters ?
- Water being burned off after sitting?
- Flywheel / flexplate
- Leaking intake on 400
- Is the 400 2bbl Intake a "Wet Intake"?
- what would cause my 400m to back fire thought the carb??
- After Market Oil Pressure Gauge Sender Location on a 400
- ride with me... build issues
- Headers
- Quick question about initial timing and distributor location.
- roller rockers
- bending pushrods
- 400 with 351c heads, header question
