- Would Like to put more oomph to the tires
- 351 engine help
- truck pulling
- oil pump shaft which way?
- bad motor mount?
- 351 or 460
- I need a torque figure! Help!
- Comp ratio of 56-58cc Aussie heads, on stock 351C
- motor swap
- Aussie heads, now what?
- differences between a 351 c/m/w????????
- 351 cleveland stock
- Lurching problem
- Help identifying engine please
- Identifying a 351 Cleveland
- 400 with 800hp
- 351 cleveland in Mercury Comet
- motor mount question
- "bearing in oil pan"
- 1996 FI 351M Low RPM Problem.
- egr help
- A Dream 400 M Engine
- harmonic balancer removal
- 351c PS pulley not lining up.
- 1982 F-250 351M
- Head id
- 351c Stuck Distributor
- Building a 400M Need all your opinions
- 77 400 Gas to Propane Conversion--cost and will it pass smog test
- Roller Rocker Conversion Kits
