- 351M to 400 ?
- Compatable starters?
- Crank material
- distributor 351M
- ignition system
- Coil Connector Removal
- What engine do I have ?
- Stock HP/Torque from a '79 400?
- High pressure vs. high volume
- 351m transmission
- timing 1977 400 a/t 4x4
- Stroker Piston
- 4bbl carb to 2bbl intake??
- Puffing 400
- 400 in a 73 ?
- 351M rear main
- which manifold???
- "thin" bore block?
- ignition timing
- 400 transmission selection
- 351M Help
- where at
- 351c flywheel on 351M / 400
- Spark Plug Thred Problem
- i don't know
- Flywheel for 351M/400 ?
- weird problem
- Timing Cover Install
- need info bad
- an M/400 in the Engine Masters?
